T_Altland27 Posted June 2, 2014 Share Posted June 2, 2014 Looking to do the lightweight crank pulley bow for those of you who put this in yourselfs do you need a special tool or not I don't wanna buy it then come to figure out that I need the tool to install it so if any could answer that be great thanks Link to comment Share on other sites More sharing options...
bomberlegacy Posted June 2, 2014 Share Posted June 2, 2014 No you do not. Auto or manual trans, there are ways to keep the motor from turning. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
T_Altland27 Posted June 2, 2014 Author Share Posted June 2, 2014 Ok thanks bomber just wanted to make sure before I went ahead and bought one Link to comment Share on other sites More sharing options...
1stick3pedals Posted June 3, 2014 Share Posted June 3, 2014 A really long piece of tubing helps. I use the bar from my floor jack (has to be 3'-4' long) on a breaker bar for crank pullies and axle nuts. Link to comment Share on other sites More sharing options...
T_Altland27 Posted June 4, 2014 Author Share Posted June 4, 2014 No you do not. Auto or manual trans, there are ways to keep the motor from turning. Bomber I got the m/t do you have a diagram to show where to stick a screw driver to keep the motor from turning? Link to comment Share on other sites More sharing options...
1stick3pedals Posted June 5, 2014 Share Posted June 5, 2014 E-brake pulled, transmission in 5th gear, and a friend pressing on the brake should work. Wheel chocks would help too. Link to comment Share on other sites More sharing options...
T_Altland27 Posted June 5, 2014 Author Share Posted June 5, 2014 Ok thanks for the tip might have off work tommorow so I think I'll give her a shot Link to comment Share on other sites More sharing options...
1stick3pedals Posted June 5, 2014 Share Posted June 5, 2014 Ok thanks for the tip might have off work tommorow so I think I'll give her a shot Good luck! I actually used that technique just a couple weeks ago when I had to remove the crank pulley on my FXT to do a TB job. Link to comment Share on other sites More sharing options...
