legacydh Posted August 31, 2013 Share Posted August 31, 2013 I have 98 L wagon and when I'm getting off of the highway, or braking at speed, my car gets a pretty violent shake? What gives? I just have two new axles and brakes done and the shake persists. City driving isn't bad at all but if I'm slowing down from 50 or faster, the ol' wagon shakes like a bitch. Any help would be appreciated. Link to comment Share on other sites More sharing options...
road race legacy Posted August 31, 2013 Share Posted August 31, 2013 Did you install new rotors when you did the brakes? Link to comment Share on other sites More sharing options...
mnstrmech Posted August 31, 2013 Share Posted August 31, 2013 if it happens while your braking, that would be rotors causing that. Or the brake job in general. Rust develops between the hub and rotor and when you install new rotors you should clean the rust from the hub. Thats one way you can get pulsation. The other would prolly be whoever did the job didn't torque the lug nuts properly. Thats an- important step. Believe it or not, Subaru's lug nut torque should only be 58-72 ft lbs. Im anal about that. Link to comment Share on other sites More sharing options...
Scruffy Posted August 31, 2013 Share Posted August 31, 2013 yup yup, rotors. Mine had that Link to comment Share on other sites More sharing options...
monkeyposeur Posted September 1, 2013 Share Posted September 1, 2013 A crappy ball joint can also cause shaking. You could have some buildup on your rotors too. Link to comment Share on other sites More sharing options...
jb80 Posted September 1, 2013 Share Posted September 1, 2013 Could also be caused by tires. I had a terrible shake when I'd let off the gas from highway speeds, and it turned out to just be tires. Â Now what caused the tires to wear that way? I'm not sure. But it's been about 6 months and it hasn't returned. Link to comment Share on other sites More sharing options...
pleaidestar Posted September 1, 2013 Share Posted September 1, 2013 Win your car off and the steering lock free, turn your wheel back and forth, if there is excessive play in there means you have bad inner or outer tie rods, but you need to look at which one is moving. Keep in mind thee will be play normally but not a noticeable amount. I just replaced my outer tie rods for that reason. About a year ago my front rotors had some run out and when I replaced them it helped a little as well..but ultimately the outer tie rods caused most of the shaking. Link to comment Share on other sites More sharing options...
Tr00b Posted September 2, 2013 Share Posted September 2, 2013 Bad tie rod end is doing it to me. Link to comment Share on other sites More sharing options...
jb80 Posted September 2, 2013 Share Posted September 2, 2013 Win your car off and the steering lock free, turn your wheel back and forth, if there is excessive play in there means you have bad inner or outer tie rods, but you need to look at which one is moving. Keep in mind thee will be play normally but not a noticeable amount. I just replaced my outer tie rods for that reason. About a year ago my front rotors had some run out and when I replaced them it helped a little as well..but ultimately the outer tie rods caused most of the shaking. I suspect that's my problem. I have quite a bit of play. Thank you! Link to comment Share on other sites More sharing options...
legacydh Posted September 2, 2013 Author Share Posted September 2, 2013 Thanks a bunch, guys. Going in on Tuesday to have the problem fixed. Definitely need new rotors and will have them look at the tie rods. Doesn't seem to be excessive play in the steering so I'm going to to assume it's the rotors. I should probably just go up to the H6 upgrade if I'm going to go thru the trouble, huh? Anyway, thanks again for the help, gentlemen. Link to comment Share on other sites More sharing options...
legacydh Posted September 2, 2013 Author Share Posted September 2, 2013 Wait....is the H6 just for the rears? So a '02 WRX brake set up would work for my fronts? Link to comment Share on other sites More sharing options...
pleaidestar Posted September 2, 2013 Share Posted September 2, 2013 Yes...and yes. You'll need to do a thing or two to make them work as well as have wheels bigger than 15" for the wrx calipers to clear your wheels. Gotta drill the heat/dust shields off the knuckle..etc, here is a write up in the upgrades sticky that zues marine has put together. Link to comment Share on other sites More sharing options...
road race legacy Posted September 2, 2013 Share Posted September 2, 2013 Most likely then pad deposits on the rotors or they are warped. Link to comment Share on other sites More sharing options...
twisty Posted September 3, 2013 Share Posted September 3, 2013 same thing lots of shuddering when stopping from 50+, my rotors warped while on my cross country trip last year, turned the rotors and new pads in michigan and the problem went away. of course, it didnt help the bad ball joints or tie rod ends issue, those are on the short list for that car. Link to comment Share on other sites More sharing options...
legacydh Posted September 22, 2013 Author Share Posted September 22, 2013 so it turns out that the problem was a combination of needing new rotors and an unbalanced wheel. problem solved. thanks again, guys. Link to comment Share on other sites More sharing options...
kurtis9813 Posted September 23, 2013 Share Posted September 23, 2013 I used to gave that with my snow tires. Then I got all seasons and hadn't happened since. Link to comment Share on other sites More sharing options...
