KTM 525 Posted May 1, 2005 Share Posted May 1, 2005 Starting to annoy me. I can shift 1st to 2nd ,2nd to 3rd at high rpm fast without a problem.If I go to shift fast into 4th I get a grind. It does go into 4th but with a grind:mad: . This has been developing as of late and has not happened since new. Shifts fine into 4th under normal driving.Kinda tough to tell a dealer about this issue I guess. Anyone else have this? Link to comment Share on other sites More sharing options...
Deer Killer Posted May 2, 2005 Share Posted May 2, 2005 4th was the first gear I noticed I had problems with. I mean forget about grind, just wouldn't go past the synchro's at all. Doing a 3rd->4th shift from 3rd at about 5500-6500 rpm. Link to comment Share on other sites More sharing options...
meier motor sports Posted May 2, 2005 Share Posted May 2, 2005 yeah i have had problems getting into 4th at high rpms. and a few other gears seamed to have a harsh eguagement at high rpm. i was wondering if a short throw shifter and/or fluid change would would help anything? Link to comment Share on other sites More sharing options...
Deer Killer Posted May 2, 2005 Share Posted May 2, 2005 Short throw does not, fluid change is probably just bandaging the symptoms.. It's gotta be something with the clutch assembly. Link to comment Share on other sites More sharing options...
KTM 525 Posted May 2, 2005 Author Share Posted May 2, 2005 If it were the clutch assembly then would'nt it do this in other gears as well? No other problems at high rpm except 3rd to 4th. I have a Kartboy SS since the car was new. What was your remedy Deerkiller? Link to comment Share on other sites More sharing options...
Deer Killer Posted May 2, 2005 Share Posted May 2, 2005 reported my problem to my dealer.. waiting... just like the stuttering issue. It took me more driving time to find when/how/what it was doing it in other gears, but each gear seems to be a little different, but still misbehaving at certain times. so *shrug* Link to comment Share on other sites More sharing options...
Opie Posted May 2, 2005 Share Posted May 2, 2005 Synchro issues cause grinding and harsh engagement...speed shifting causes synchro issues... Link to comment Share on other sites More sharing options...
John M Posted May 2, 2005 Share Posted May 2, 2005 I've had what DK described happen just once or twice at the most. I'm hoping it's related to powertrain flex and can be fixed with a better tranny brace. Otherwise it could become a huge PITA down the road. Link to comment Share on other sites More sharing options...
gfxdave99 Posted May 2, 2005 Share Posted May 2, 2005 That most def sounds like a synchro problem.. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
rkl303 Posted November 7, 2006 Share Posted November 7, 2006 I am getting that occasionally now too...the grind is pretty light, but still very annoying. I am going to try and add a little more tranny fluid tonight. If I hold off for a bit then throw it into gear it doesnt seem to be a problem. Link to comment Share on other sites More sharing options...
PhilT Posted November 7, 2006 Share Posted November 7, 2006 Definately sounds like the synchro. I found to my cost that it is possible to shift faster than the gearbox allows, and I now have to get the synchro between 1st and 2nd replaced. I seem to recall reading somewhere that a lightweight flywheel and STS can exasperate this problem, but can't for the life of me remember where. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
whitetiger Posted November 7, 2006 Share Posted November 7, 2006 I have the same problem going in to 4th gear. it definitly feels like a synchro. if you shift slower it goes in fine, but if you shift fast, it grinds and then goes in. Its odd that the 4th gear synchro would go since i never beat it in to that gear 2nd and 3rd gears are what get most of the abuse. Link to comment Share on other sites More sharing options...
j255c Posted November 7, 2006 Share Posted November 7, 2006 i get it in 5th gear. above 85 if i shift fast into it. Hrmmm SOA we have a problems arising. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
rkl303 Posted November 19, 2006 Share Posted November 19, 2006 Any chance you guys changed your tranny fluid to redline 75w90ns? I really notice this only when the car is warmed up and for some reason it has dissappeared lately. Link to comment Share on other sites More sharing options...
darren94 Posted November 19, 2006 Share Posted November 19, 2006 Synchro issues cause grinding and harsh engagement...speed shifting causes synchro issues... + 1 Link to comment Share on other sites More sharing options...
undert0e Posted November 19, 2006 Share Posted November 19, 2006 Any chance you guys changed your tranny fluid to redline 75w90ns? I really notice this only when the car is warmed up and for some reason it has dissappeared lately. How do you like Redline? Are you using their motor oil as well? Link to comment Share on other sites More sharing options...
rkl303 Posted November 20, 2006 Share Posted November 20, 2006 No I am too cheap to buy their oil right now...but since I saw that Mobil 1 might not be all group 4 oil anymore I might make the switch to redline or find german castrol although that bumps up oil changes to $10 or $20. I really can't tell the difference between the redline and the OEM stuff. My friend said that the OEM oil in my tranny still looked new when he was draining it. Link to comment Share on other sites More sharing options...
new2subu Posted November 21, 2006 Share Posted November 21, 2006 I changed my fluid just last weekend to Redline (NS type) because of harsh engagement from 2nd to 3rd when shifting quickly before car is fully warm. So far, I can only report marginal improvement. I want to drive it some more before I make any final determinations. I also want to check fluid level. Mechanic was able to fit in only 3.5 quarts. Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted November 21, 2006 Share Posted November 21, 2006 I am getting this harsh engagement in 5th gear when I shift at high RPMs. At first I thought maybe I was clutching out a little, but even if i hold it down for a few seconds and shift it will grind. But if im driving at a normal condition it shifts fine. I just had my tranny fluid changed at the dealer and it didnt help. Link to comment Share on other sites More sharing options...
LawGT Posted November 21, 2006 Share Posted November 21, 2006 I get a harsh engagement into 3rd gear... it's very notchy going into 3rd, not quite a grind when going in, but you definitely fele somehting. (I had the subaru STS installed at the dealer when new). When I took it a while back for this issue, the tech at the dealer told me that it shifted normal. But then again, he also said that the clutch stink is normal if you slip the clutch... Do I also have a synchro issue in 3rd? Link to comment Share on other sites More sharing options...
undert0e Posted November 26, 2006 Share Posted November 26, 2006 Clunky shifting and grinding arte usually tell tale signs of syncro issues. Do a fluid swap and see it the problem persists. just my .02. Link to comment Share on other sites More sharing options...
caramall2 Posted November 28, 2006 Share Posted November 28, 2006 I thought synchro problems usually showed up when down shifting , not upshifting, but I'm not smart on this. Anyway, I had downshifting problems and it turned out to be a bad 4th gear syncro (I had to double clutch to keep it at bay). Dealer replaced under warrantee. Link to comment Share on other sites More sharing options...
D0WNxSH1FT Posted November 28, 2006 Share Posted November 28, 2006 Hey I read on nasioc about some concoction that is supposed to be better than any other tranny fluid. Uncle Scotty's Cocktail: LW Shockproof: 8.99 Castrol 80w90: 4.29 x 2 Penzoil Syncromesh: 6.09 Link to comment Share on other sites More sharing options...
thematador Posted August 24, 2007 Share Posted August 24, 2007 Any updates on this??? I got my car used and I'm experiencing the same thing... 3rd and 4th gear. Should I get a new tranny from the dealership??? Link to comment Share on other sites More sharing options...
RobE Posted August 24, 2007 Share Posted August 24, 2007 after about 2 months of having my '06, i got that very same grind, going into 4th at high revs. it happened for a couple of months and it never came back in about 14 months. http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
