Tehnation Posted March 27, 2014 Share Posted March 27, 2014 So I had upgraded fuel pump to dw65c, and everything was working fine. Then it started having trouble starting when the gas was low, I figured I must have thrown off the float sensor, but now the problem is occurring with full tank of gas. Any ideas? I'm guessing fuel pressure regulator. The only thing I haven't replaced yet. Would a blown fpr prevent my car from priming and rough idling when it actually does fire up? Link to comment Share on other sites More sharing options...
Tehnation Posted March 27, 2014 Author Share Posted March 27, 2014 BAH, why is this part so hard to find. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 27, 2014 Share Posted March 27, 2014 Isn't the FPR on the side of the fuel rail or right there close to it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted March 27, 2014 Author Share Posted March 27, 2014 I mean a replacement No one has it in stock. Part number 22670AA381 Link to comment Share on other sites More sharing options...
Tehnation Posted March 30, 2014 Author Share Posted March 30, 2014 Found that part replaced regulator fired right up. If anyone has starting issues or idle issues, make sure to check fuel pressure. Seems like mine was shot for a while now. I didn't get the entire assembly just the 80 dollar regulator part, takes about 30-60 minutes to change. Link to comment Share on other sites More sharing options...
JJr Posted March 30, 2014 Share Posted March 30, 2014 Post the part # used and where you bought it here: http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238.html Link to comment Share on other sites More sharing options...
