SpecBamf41 Posted February 8, 2012 Share Posted February 8, 2012 I know me, and alot of others had quick questions. so here is mine for the hour. Would someone selling a turbo kit that he threw together for some chevy car, that only turob specs i was able to get so far off the add are .70A/R cold- .64A/R hot, and its a T3/T4 would this be enough info to determine if it good turbo for my build? i looking to push a max of 20 psi. min 13. BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted February 8, 2012 Share Posted February 8, 2012 That tells you not much of anything. it has a t3/t4 flange and the size of hot and cold. It could be an ebay turbo that is a POS. What motor are you going to run 20psi on? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted February 9, 2012 Author Share Posted February 9, 2012 Well 20 Max. I'm building a short block atm. Its rebranded garrat turbo that was used to push 440 whp on a 2.4 caviler It has 4 inch inlet and a 2.5 outlet. I know its a bit over kill but it will be set up with a external waste gate. BNR18g on 93oct Link to comment Share on other sites More sharing options...
SpecBamf41 Posted February 9, 2012 Author Share Posted February 9, 2012 Quick question about the greddy emanage, in our cars, we have to basically wire them in ourself wire by wire. possible right? and then what other sensors would be needed to boost our car with the factory ecu if the only thing im changing for the ecu is fuel air and spark, which is all handled by the emanage. BNR18g on 93oct Link to comment Share on other sites More sharing options...
subikid90 Posted February 9, 2012 Share Posted February 9, 2012 Well 20 Max. I'm building a short block atm. Its rebranded garrat turbo that was used to push 440 whp on a 2.4 caviler It has 4 inch inlet and a 2.5 outlet. I know its a bit over kill but it will be set up with a external waste gate. Good luck with that. I sure hope your block can handle it. What block are you using and who is building it? Thats a large turbo and running at 20psi will be overkill. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
WESTcoast Posted February 9, 2012 Share Posted February 9, 2012 hopefully you have gone with somthing that is a semiclosed deck ej20, ej255,7, to handle that much preasure, what kind of internals are going into this monster?? Link to comment Share on other sites More sharing options...
SpecBamf41 Posted February 12, 2012 Author Share Posted February 12, 2012 ok maybe 20 psi is to much? how much do sti's run stock and what can they handle stock? my weakest link i have right now is sti pistons. and me and my teacher for school are building it. just trying to beat my friends gst running 18 pounds though a 4g63? is 20 pounds overkill for that goal? BNR18g on 93oct Link to comment Share on other sites More sharing options...
EPlascencia60 Posted February 12, 2012 Share Posted February 12, 2012 Running more boost doesn't make you faster, it all depends the entire build. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted February 12, 2012 Author Share Posted February 12, 2012 i do have an entire build? but im starting to think 15 pounds in a 4g63 is not the same(track time) as 15 pounds the general sti motor. basically what im building. BNR18g on 93oct Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted February 14, 2012 I Donated Share Posted February 14, 2012 STI pistons are garbage. They like to get cracked ring lands....and its not a question of if it will happen...but when it will happen....and when you're starting to push more power then they were intended for, bad things will happen really fast. You should seriously just buy decent internals and do it right the first time instead of trying to frenkenstein one piece off every Subaru on the road into one engine. Your engine build is a big BOOM waiting to happen if you use 257 pistons -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SpecBamf41 Posted February 15, 2012 Author Share Posted February 15, 2012 ok what is safe limit then? ill consider forged BNR18g on 93oct Link to comment Share on other sites More sharing options...
Baddog Posted February 16, 2012 Share Posted February 16, 2012 And a 4G63 can handle a boat load of boost without breaking a sweat. I will give them that. The 4g63 is a brick shit house. However it is still a mitsu. You will have the weight advantage I believe though. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted February 16, 2012 Author Share Posted February 16, 2012 the eclipses weight less then the legacy for sure.. and yea a shit brick house, what a bitch to work on too! first time for both us and it took us 3-5 days after school to get the head off the car. and i can pull my engine and take the head(s) of in 5 hours on a bad day. BNR18g on 93oct Link to comment Share on other sites More sharing options...
