AMileHighLGT Posted June 18, 2014 Share Posted June 18, 2014 I knew the day would come owning one of these cars, but i certainly wasnt expecting it this soon. Cylinder 4 misfire- Plugs are new, swapped coils, swapped injectors, getting good injector pulse from pcm. Its a very consistent misfire at idle only. Enough to flag the p0304 code. I have yet to do a compression and leak down test, I suspect a burned valve. A month back when I replaced the spark plugs, the plugs from 2 and 4 looked shitty. Now I know for sure the fucked fuel trims i have been dealing with are not a leak. Sitting at my shop now, hopefully sometime by teh end of the week i will have a better idea of what exactly im dealing with. At this point with 104k on it, I am almost inclined to do an engine, really want the 257 block with crank and rods and some forged cp pistons. eventually would like to do a pump and injector upgrades for corn and a hta68. Need some opinons from some of you, if you would please. Link to comment Share on other sites More sharing options...
boxkita Posted June 18, 2014 Share Posted June 18, 2014 start here - http://legacygt.com/forums/forumdisplay.php/turbo-powertrains-2-0gt-2-5gt-2-5xt-12.html Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
AMileHighLGT Posted June 18, 2014 Author Share Posted June 18, 2014 Ive been searching in through the turbo power train forums since yesterday morning. A quick search at lunch yesterday only yielded a hand full of threads over a 257 block swap. Still havent read the technical bits on the forged pistons. Nasioc seems to be filled with 257 threads, i dislike their search engine.. Thanks Box. Link to comment Share on other sites More sharing options...
AMileHighLGT Posted June 19, 2014 Author Share Posted June 19, 2014 Compression test results 1-115 2-105 3-110 4-50. Leaking past the rings. Boroscope shows some gouges on the cyl walls. Sent from my XT907 using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted June 19, 2014 Share Posted June 19, 2014 who did you buy it from? someone on this forum? or from CL/dealer? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
AMileHighLGT Posted June 19, 2014 Author Share Posted June 19, 2014 I bought it from a well known Subaru dealer in Denver that at this time I won't name. Sent from my XT907 using Tapatalk Link to comment Share on other sites More sharing options...
Dujo Posted June 19, 2014 Share Posted June 19, 2014 Use google to search nasioc and other forums. Just include "site:legacygt.com" or similar for nasioc, etc in your search box. Link to comment Share on other sites More sharing options...
tommypenguin Posted June 19, 2014 Share Posted June 19, 2014 Have you engaged the subaru dealer to see if they will do anything for you regarding a new engine? Is it looking like you will need a full long block? Stock short block a few years ago for both halves used to only run about 1800$, not counting the gasket/seals kit. Link to comment Share on other sites More sharing options...
AMileHighLGT Posted June 19, 2014 Author Share Posted June 19, 2014 I have not spoken with the dealer. I don't suspect they will be of any assistance. I battled with them for a month over a prenegotiated rear link bushing that they were supposed to replace. At that time I asked for a leakdown test as well due to 2-3 cold starts that blew some smoke. They fought with me on it, and since they "did not duplicate" the smoke they didn't perform a leak down test. Sent from my XT907 using Tapatalk Link to comment Share on other sites More sharing options...
boxkita Posted June 19, 2014 Share Posted June 19, 2014 I have not spoken with the dealer. I don't suspect they will be of any assistance. I battled with them for a month over a prenegotiated rear link bushing that they were supposed to replace. At that time I asked for a leakdown test as well due to 2-3 cold starts that blew some smoke. They fought with me on it, and since they "did not duplicate" the smoke they didn't perform a leak down test. Sent from my XT907 using Tapatalk Water over the dam at this point, however, that should have been your clue to walk. I thought you might have bot doc's car. A well optioned car sold about that time to a local denver person. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
AMileHighLGT Posted June 19, 2014 Author Share Posted June 19, 2014 Water over the dam at this point, however, that should have been your clue to walk. I thought you might have bot doc's car. A well optioned car sold about that time to a local denver person. I understand it doesn't matter now. wouldnt have been able to walk away from it then, because it was already in our possession. I did my own prepurchase inspection. I regret now not doing a compression test, did pull the dp and checked shaft play. wasn't aware the engines were prone to ringland failures. Now, if what I've read is correct, there is a certain year ej257 that needs to be used due to avcs, correct? Sent from my XT907 using Tapatalk Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted June 19, 2014 Moderators Share Posted June 19, 2014 no, any year ej257 will work. AVCS doo-dads are in the heads. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
