lmlght14 Posted March 31, 2015 Share Posted March 31, 2015 My 08 LGT is making a high pitched noise that I cannot figure out the source. It sounds like it a rotational noise but I haven't been able to confirm that. Both front wheel bearings were replaced 3 weeks ago and there has been no change in the noise. When I turn the wheel to the right, the noise always goes away. Also, when I brake the noise always goes away. Any ideas are really appreciated. Thank you! Recording of the noise: Link to comment Share on other sites More sharing options...
FJuan Posted March 31, 2015 Share Posted March 31, 2015 What is that clunking noise? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Scubaru03 Posted March 31, 2015 Share Posted March 31, 2015 Sounds like a possible up pipe leak. Is its backfiring? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
lmlght14 Posted March 31, 2015 Author Share Posted March 31, 2015 Clunking is the sound of the suspension going over bumps/potholes on the highway. Suspension is Swift springs, Koni yellow struts/shocks, Hotchkis F&R sway bars and end links and Perrin positive steering offset kit. No backfiring. Link to comment Share on other sites More sharing options...
FJuan Posted March 31, 2015 Share Posted March 31, 2015 It has a sound like a timing belt pulley is bad. Have you listen inside the engine bay to determine if it's coming from there? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
700watts Posted March 31, 2015 Share Posted March 31, 2015 Manual ?...hope I'm wrong, but that be your throw out or thrust bearing my friend. At least that's what it sounds like. Link to comment Share on other sites More sharing options...
apexi Posted March 31, 2015 Share Posted March 31, 2015 I agree, my guess would be throw out bearing. MT? If so, how many miles on the clutch? Link to comment Share on other sites More sharing options...
lmlght14 Posted March 31, 2015 Author Share Posted March 31, 2015 I have tried listening inside the engine bay but since the noise isn't consistent I haven't been able to hear it when I've been listening. Sorry, I should have added this info earlier, it's a 5EAT-S. Link to comment Share on other sites More sharing options...
FJuan Posted March 31, 2015 Share Posted March 31, 2015 Can you hear the noise when the car has come to a stop? Or only when driving? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
lmlght14 Posted March 31, 2015 Author Share Posted March 31, 2015 Only when driving. It's not a consistent noise though and I haven't figured out what triggers it. Distance, speed, ambient temp, bumpy vs smooth roads don't seem to consistently trigger the noise or amplify the noise. I hope that makes sense. Link to comment Share on other sites More sharing options...
FJuan Posted March 31, 2015 Share Posted March 31, 2015 Does the pitch go higher when driving faster? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
lmlght14 Posted March 31, 2015 Author Share Posted March 31, 2015 The pitch is pretty consistent. Your question got me thinking and I don't recall hearing the noise above 70/75 mph. The speed of the noise changes with the speed of the car which is why I think it may be something rotational but I'm not sure. Link to comment Share on other sites More sharing options...
FJuan Posted March 31, 2015 Share Posted March 31, 2015 You said you had the front bearing replaced recently, what about the rears? My rear bearings went out before my fronts, and I remember hearing the sound of marbles in a tin can. You may want to inspect the rear bearings. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
lmlght14 Posted March 31, 2015 Author Share Posted March 31, 2015 Correct, the fronts were replaced 3 weeks ago. The rears have not been done so I'll take a look at them. Link to comment Share on other sites More sharing options...
travrach Posted March 31, 2015 Share Posted March 31, 2015 Lol, at 1st I was like the cars not moving, haha. Seeing how it changes when you slightly turn the wheel it's more then likely in the brakes. 1.The small clips that are under the pads can just be out of line a little bit and the sway of the car makes the rotor just touch them. 2. Or it's the brake pad warning tabs. 3. Or it's the rotor touching the backing plate. These are typical items that make that noise when you turn the wheel. Very easy to fix if you can do a front brake job you can check those 3 items. Link to comment Share on other sites More sharing options...
lmlght14 Posted March 31, 2015 Author Share Posted March 31, 2015 Thanks for the suggestions. I'll check those out. Link to comment Share on other sites More sharing options...
