waxon_waxoff Posted December 9, 2011 Share Posted December 9, 2011 I already did a search for this and did find some relevant results. One thread described popping off the shroud and then adjusting a gold screw to aim the fogs higher or lower. I popped off the shroud, but can't seem to find this screw. The original thread was describing this for an 05 - I didn't think there was a difference between the 05-06 fogs and the 07s, although maybe I'm wrong. I have already changed the bulbs once, and went through the procedure of removing the assemblies from the bumper - I hope I don't need to access the assemblies from behind.......? thanks Link to comment Share on other sites More sharing options...
MiniStiGuy Posted December 10, 2011 Share Posted December 10, 2011 the screw is on the side of the lamp. Its kind of back there so look real good and you will see the screw head. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
waxon_waxoff Posted December 13, 2011 Author Share Posted December 13, 2011 i am either blind or.... i dunno. feel stupid even asking this stuff cuz it seems so simple. but i seriously can't find this stupid screw! is it accessed from the side of the foglight enclosure, requiring the removal of the plastic dirt shield/skid plate behind the bumper? or can it be accessed after simlpy removing the plastic surrounds for the foglights? Link to comment Share on other sites More sharing options...
feelander Posted December 13, 2011 Share Posted December 13, 2011 07 legacy does not have the adjustment screws on the front of the foglight. You must access the black turning knob on the back of the foglight assembly. Easy to access if you remove the small splash guard under each side. Link to comment Share on other sites More sharing options...
waxon_waxoff Posted December 13, 2011 Author Share Posted December 13, 2011 07 legacy does not have the adjustment screws on the front of the foglight. You must access the black turning knob on the back of the foglight assembly. Easy to access if you remove the small splash guard under each side. aaaaaaaaaaaarg. ok sweet thanks Link to comment Share on other sites More sharing options...
RabidWombat Posted December 15, 2011 Share Posted December 15, 2011 The stupid screws are actually recessed into pieces of plastic. You can use your cell phone to take a picture and figure out where the screws are. Your best bet is to turn your wheels all the way inside to give you the best access. Link to comment Share on other sites More sharing options...
