squirrel_jester Posted April 18, 2018 Share Posted April 18, 2018 2005 Legacy GT 134k miles Headgasket is leaking exhaust into the coolant. First symptom was a crack at the top of the radiator (replaced radiator). Next symptom was overheating and coolant reservoir turning black/loss of coolant. I did the coolant pressure test and it came back negative. I then performed the chemical block tester and it came back positive for exhaust gases in the coolant. I have a question before I yank the engine out and get it repaired. Besides new valve cover/head gaskets, planing/checking the heads/valves, what else would you check for or replace with the engine out? I already have a hotrodded WRX, and this Legacy will be my DD. It's on a Stage 2 OTS Cobb tune. I am not looking to upgrade engine internals . Any advice is appeciated. Thanks. Link to comment Share on other sites More sharing options...
relative4 Posted April 18, 2018 Share Posted April 18, 2018 Timing belt & tensioner if not done recently Oil cooler gasket Up-pipe if not already done Consider clutch & flywheel if applicable; if manual but keep clutch, replace TOB Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 18, 2018 Author Share Posted April 18, 2018 Timing belt & tensioner if not done recently Oil cooler gasket Up-pipe if not already done Consider clutch & flywheel if applicable; if manual but keep clutch, replace TOB Timing belt done @ 100k Oil cooler gasket is a good idea Up-pipe is done 5EAT Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2018 Share Posted April 19, 2018 Heater hoses ARP head studs Heads should be reconditioned by a good machine shop 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 19, 2018 Author Share Posted April 19, 2018 I'll check the heater hoses condition and replace if showing signs of aging. Definitely going with ARP head studs. I'm considering running 1-step colder plugs, and I believe I need to get a custom tune for them. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2018 Share Posted April 19, 2018 Both my cars run 1-step colder, both have custom tunes. Though I don't believe they need a custom tune. I run them because they are less money. I see your in P-ville TX, is that Plano TX ? I know guy there that's kind of a great Tuner. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 19, 2018 Author Share Posted April 19, 2018 Both my cars run 1-step colder, both have custom tunes. Though I don't believe they need a custom tune. I run them because they are less money. I see your in P-ville TX, is that Plano TX ? I know guy there that's kind of a great Tuner. Pflugerville I thought they required a custom tune due to needing slightly more fuel for spark? I understand how the plugs work, but not sure on injector tuning associated with them. Talking about tuners, I use Torqued Performance - Eric Minehart for my WRX. The consensus on the forum seems to be a guy named Mike for the Leggys? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2018 Share Posted April 19, 2018 That would be Mike Kinsman of http://www.tuningalliance.com He really is the best if not one of a few. Just east of Plano TX, Tony Palo of https://www.t1racedevelopment.com/ He helped us a lot back in our Honda race car day's. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Mtman68 Posted April 21, 2018 Share Posted April 21, 2018 Also check front and rear crank seals while engine is out. Sometimes the rear access plate can seep oil that is behind flywheel/flexplate. Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 23, 2018 Author Share Posted April 23, 2018 Will do. I had to reseal the oil separator plate on my WRX 2 weekends ago. Fun times. Link to comment Share on other sites More sharing options...
97outbackron Posted April 23, 2018 Share Posted April 23, 2018 Just curious why you would pull the entire engine instead of just pulling the head? New head bolts, new head gasket, send head out to machine shop. I'm not overly familiar with my Subaru since I haven't had it all that long, but I would probably do the water pump as well. I'd hate to do all that work to the head and then have the pump go out and blow the head gasket again due to overheating. Been there............. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 23, 2018 Share Posted April 23, 2018 It's a big job either way. With the engine out you have lots of room to do things right instead of bending over the fender and risking your back. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
97outbackron Posted April 24, 2018 Share Posted April 24, 2018 It's a big job either way. With the engine out you have lots of room to do things right instead of bending over the fender and risking your back. I certainly can't argue with that! Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 24, 2018 Author Share Posted April 24, 2018 I'm a tall guy and being bent over with the engine in the car is no fun for me. Also, it's not too much trouble to pull the engine out vs keep it in the car. If this was an inline or v engine, it would be a different story. I've pulled more than a few subaru engines before. These engines are like legos. Link to comment Share on other sites More sharing options...
SubOperator Posted April 25, 2018 Share Posted April 25, 2018 Looks like you are on right track. I'd add few smaller things - tighten screws on fuel hoses where they connect to fuel rails, those loosen up after a while and leak a little. TB rollers since TB will be coming off anyway; and yes water pump if it wasn't done yet. Small gaskets on intake while you have it off. Injector seals if you feel spendy. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
Max Capacity Posted April 25, 2018 Share Posted April 25, 2018 If I haven't already said so, look through my click here link and see what's involved in pulling the engine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 26, 2018 Author Share Posted April 26, 2018 Looks like you are on right track. I'd add few smaller things - tighten screws on fuel hoses where they connect to fuel rails, those loosen up after a while and leak a little. TB rollers since TB will be coming off anyway; and yes water pump if it wasn't done yet. Small gaskets on intake while you have it off. Injector seals if you feel spendy. What are TB rollers? Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 26, 2018 Author Share Posted April 26, 2018 If I haven't already said so, look through my click here link and see what's involved in pulling the engine. Thanks for the suggestion Max. Excellent post you made. I'm sure I'll refer to it and the pics/videos I take when putting it all back together again. -Humpty Dumpty Link to comment Share on other sites More sharing options...
relative4 Posted April 26, 2018 Share Posted April 26, 2018 What are TB rollers? Timing belt idler pulleys Link to comment Share on other sites More sharing options...
squirrel_jester Posted April 26, 2018 Author Share Posted April 26, 2018 I was thinking turbo back or throttle body, so I was all confused. Thanks. TMDA (Too Many Damn Acronyms) Link to comment Share on other sites More sharing options...
