Landcruisin60 Posted July 10, 2008 Share Posted July 10, 2008 I got a free 2002 Legacy L auto but it was from my parents so I'm not going to argue. I want to make it more powerful and handle better. I was thinking intake, exhaust, chip (??) lower it an inch or so and maybe bigger sway bars. Whats the best way to go about getting more power? I dont have the money to spend $3500 on a turbo. But I was hoping to get like 180-200awhp. Is that too much to ask? The issue is I cant find any parts for it. All the parts are for the newer gen Legacys. Whats the difference between my L and the GT of the same era? Can someone send me in the right direction for performance parts? Thanks Link to comment Share on other sites More sharing options...
subaru_terrence Posted July 14, 2008 Share Posted July 14, 2008 200WHP!? you gotta be kidding me... more like 200 hp to the crank max.. Link to comment Share on other sites More sharing options...
ShrinerMonkey Posted July 14, 2008 Share Posted July 14, 2008 200hp to the crank is pushing it without some sort of forced intake. Link to comment Share on other sites More sharing options...
RiffRat Posted July 15, 2008 Share Posted July 15, 2008 I got a free 2002 Legacy L auto but it was from my parents so I'm not going to argue. I want to make it more powerful and handle better. I was thinking intake, exhaust, chip (??) lower it an inch or so and maybe bigger sway bars. Whats the best way to go about getting more power? I dont have the money to spend $3500 on a turbo. But I was hoping to get like 180-200awhp. Is that too much to ask? The issue is I cant find any parts for it. All the parts are for the newer gen Legacys. Whats the difference between my L and the GT of the same era? Can someone send me in the right direction for performance parts? Thanks OK, let's go slowly here.... Adding a CAI (Cold Air Intake....which BTW increases under hood noise), with a high flow exhaust will help, but not a ton (plus you'll need to get the ECM tuned for the reduced restrictions). Doing the above AND adding a Nitrous kit is the cheapest way to HP, BUT, YOU SHOULD NOT ADD BIG HP KITS TO THIS CAR!! The '02 L and GT have the same powertrain, but the GT's came with ground effects, bigger wheels and tires and more options. Overall, the engine and tranny aren't made like the new GT's and can't handle lots of additional HP without mod's. You can surprise a few people with a 35hp nitrous system, but you still won't take a WRX off the line, never mind a LGT turbo. (Nitrous Systems makes NOS systems that can be used without ill effect, IF you avoid temptation to go big HP...) Link to comment Share on other sites More sharing options...
Landcruisin60 Posted July 15, 2008 Author Share Posted July 15, 2008 200WHP!? you gotta be kidding me... more like 200 hp to the crank max.. That was helpful...thanks... OK, let's go slowly here.... Adding a CAI (Cold Air Intake....which BTW increases under hood noise), with a high flow exhaust will help, but not a ton (plus you'll need to get the ECM tuned for the reduced restrictions). Doing the above AND adding a Nitrous kit is the cheapest way to HP, BUT, YOU SHOULD NOT ADD BIG HP KITS TO THIS CAR!! The '02 L and GT have the same powertrain, but the GT's came with ground effects, bigger wheels and tires and more options. Overall, the engine and tranny aren't made like the new GT's and can't handle lots of additional HP without mod's. You can surprise a few people with a 35hp nitrous system, but you still won't take a WRX off the line, never mind a LGT turbo. (Nitrous Systems makes NOS systems that can be used without ill effect, IF you avoid temptation to go big HP...) So its probably not worth spending the money on any of that? I guess I'll just save my money and do a JDM swap some point in the future. Link to comment Share on other sites More sharing options...
subaru_terrence Posted July 16, 2008 Share Posted July 16, 2008 if you really wanna spend $$ on your car..you can get CAI, full exhaust with equal length headers, catless lightweight pulleys, cams, piggyback, etc etc. Link to comment Share on other sites More sharing options...
