GotTurboWut Posted October 26, 2010 Share Posted October 26, 2010 Ok, I've read quite a bit and believe it or not, I've utilized the "search" function! My car: '05 Limited, 1 owner, 47K miles, 5 auto. I've read a little about the "banjo bolt" issue. Is it really a big issue? Also, in order of mods (and trying to keep under $5-600), what should be done first? 1. From my reading, I understand the '05 has a catted uppipe which should be gutted or replaced? Any suggestions? 2. Downpipe. Looks like ERZ catted is the way to go. 3. AP (very expensive) or get the VAG-Com cable on EBAY and get INFAMOUS 1 to tune. I understand I have to use a laptop...new to tuning so must say I'm a little hesitant to do so. 4. AVO panel filter. Doesn't sound like replacing intake is cost effective since it's a good setup from factory. I guess that's it for now. Maybe down the road, a tb exhaust but not yet. Must say, this is a great site and a wealth of info. Anyone know a good, respectable, shop in Northern VA (Winchester, VA) area that has worked and tuned Subaru's? Thanks!! Link to comment Share on other sites More sharing options...
awwsheeet Posted October 26, 2010 Share Posted October 26, 2010 a 07 and up pipe is catless i think you can get a bigger one but im not sure if it makes that much of a difference unless you get headers to match Link to comment Share on other sites More sharing options...
dustincredible Posted October 26, 2010 Share Posted October 26, 2010 1. You can get an STi up-pipe for less than $75 shipped on NASIOC. Just search for it. That's what I did. 2. ERZ is a great downpipe. I have the catless version. 3. You have to pay to play. You can get a used AP on this website for $450 or less. OR you can find a Version 1 AP on this website and trade it in for a brand new Version 2 at Cobb plus $395 and you got yourself a brand new AP! 4. That filter should be fine. The stock intake is a great intake for power under 300 hp IMO. Sold: 2006 Subaru Legacy GT Spec B #104 of 500 Link to comment Share on other sites More sharing options...
robinlsb Posted October 26, 2010 Share Posted October 26, 2010 At the very least, check the banjo filter. If it is clean, leave it in and change the oil , frequently, as in hard service. Think suspension mods first. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
Max Capacity Posted October 26, 2010 Share Posted October 26, 2010 Think suspension mods first. X2 It will give you time to figure out what you really want. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DRoc7822 Posted October 26, 2010 Share Posted October 26, 2010 I did cosmetic mods first...while I did research on engine mods. Link to comment Share on other sites More sharing options...
GotTurboWut Posted October 26, 2010 Author Share Posted October 26, 2010 Thanks for the replies. Actively searching for an STI Uppipe! Link to comment Share on other sites More sharing options...
cypher0117 Posted October 26, 2010 Share Posted October 26, 2010 I to have a 'new' 05 legacy GT. The first thing I did was install the Leptronix Aux In. Next is tires. After that, its either sway bars or coilovers. I have not decided which ones to get....maybe both But I would agree with robinlsb and Max. Why put money into the car to make it go faster if the stock suspension is barely adequate for stock power levels Link to comment Share on other sites More sharing options...
05LGTLtd Posted October 26, 2010 Share Posted October 26, 2010 http://www.arfabrication.com/ Mach V is east of you, but not too far: http://www.fastwrx.com/ All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
gil_ong Posted October 26, 2010 Share Posted October 26, 2010 will any GD STi uppipe work? the goal is to eliminate the cat. right? Link to comment Share on other sites More sharing options...
Drift Motion Posted October 26, 2010 Share Posted October 26, 2010 1. You can get an STi up-pipe for less than $75 shipped on NASIOC. Just search for it. That's what I did. one question....which year STi?? Link to comment Share on other sites More sharing options...
GotTurboWut Posted October 26, 2010 Author Share Posted October 26, 2010 Car came w/ new tires from stealership...Stone Potenza go19 Grids, much better than RE92's. Yes, eliminate the cat in the UP...sounds like it can cause some perm damage to turbo. 05lgtltd-thanks for the links/suggestions on shops. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted October 26, 2010 Share Posted October 26, 2010 F&R sway bars, or at least a JDM rear sway bar... First mod every LGT owner should consider.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
joeblow Posted October 26, 2010 Share Posted October 26, 2010 Sounds like you actually worked on this before you posted. Good job. I did power before handling, but only a month or two. If you are going to do it little by little, I would start with handling. Good luck with your modding. It's cool; I'm with the band Link to comment Share on other sites More sharing options...
robbie_R Posted October 26, 2010 Share Posted October 26, 2010 one question....which year STi?? All STi's were cat-less WRX ones are catted. I'm also going for suspension mods first, already go my Cusco bars and grabbing coil overs at some point over the winter. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted October 27, 2010 Share Posted October 27, 2010 To confirm, any 04-07 STi or 07-09 LGT uppipe will work in the 05-06 LGTs. To the OP, I would do power first and suspension second. For power you are on the right track, STi uppipe, ERZ/CNT downpipe, and I would recommend the Accessport, because not only do you get the staged tunes, you can monitor your parameters realtime. As far as suspension I personally like my BC BR coilovers. On the search for a new DD... Link to comment Share on other sites More sharing options...
05LGTLtd Posted October 27, 2010 Share Posted October 27, 2010 If you really want a Cobb AP, PM me for details I have one I'm not using anymore. I've been running the grimmspeed x-pipe and up for 3+ years now with out problems. http://www.importimageracing.com/p/Grimmspeed-up-pipe-wrx-sti-lgt-fxt.html All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
Deadleave Posted October 27, 2010 Share Posted October 27, 2010 Think suspension mods first. X2 It will give you time to figure out what you really want. +100 Suspension and brakes if needed. But think really hard and realistically about what your needs are. I learned this the hard way. Do at least F/R sways... Link to comment Share on other sites More sharing options...
mwm5094 Posted October 27, 2010 Share Posted October 27, 2010 1. Replace your UP. They sell M2 racing ones on ebay for $50 brand new. Just make sure you do the resistor mod. There is a forum on how to do this. When buying up pipes I personally would try to avoid the flex joint. Over time they can leak and also break up causing damage to the turbo. 2. As far as a DP goes, ERZ is great. I personally have a COBB catless that I picked up for $100 off of a friend that was parting his out. 3. I would wait on the AP until you do a TB exhaust. 4. The stock intake setup is fine. Like someone said until you get up to 300+ hp. I just put a K&N drop in filter in my car. Im happy with it. Suspension mods are also awesome and make a huge difference, so do performance. It all depends on what you like better in my opinion. Also, look at the member FS threads if you are on a tight budget. Im in college so I know what its like. I found all of my parts at awesome prices. Lastly, some mods that make a big difference is your cars look that can be done super cheap are painting stock grille, blacking or clearing headlights, and painting wheels. You can do your grille and headlights for a can of paint. Good luck, Mark Link to comment Share on other sites More sharing options...
shutterbc Posted October 27, 2010 Share Posted October 27, 2010 I'm basically in the same boat as you are. I have decided to switch to Koni inserts as my current struts are wearing out by now... but I always think about snow handling and know that stiff sway bars are actually not a good idea on loose surfaces. That's why I'm considering installing power mods first, followed by suspension, if only because of the season. Is my logic above sound? OP might not have to consider this factor at all given his location. Link to comment Share on other sites More sharing options...
pourhaus Posted October 27, 2010 Share Posted October 27, 2010 1. Replace oil pickup tube Your mileage suggests this should be top priority. I got a 2006 GT recently and the oil pickup let go at 42,000 miles. No modifications whatsoever - it is primarily a mileage/time thing. Google "subaru oil pickup failure". I was lucky I was still under the extended drivetrain warranty and got a new short block. You won't be. I will be replacing mine again after another 20,000 miles. Link to comment Share on other sites More sharing options...
BMXBYKR Posted October 27, 2010 Share Posted October 27, 2010 GotTurboWut, My brother lives in Winchester and he has the RBP 05 LGT wagon with Black OZs. You should find him on the road and harass him lol. My first mods were Cobb RSB, STS ( I know you have the auto), Amber delete, painted grill. IMO doing the up without dp is a waste of time. I went with the grimmspeed coated up and I love it. Also someone mentioned the crossover pipe, I'd do that too, free up the exhaust flow for quicker spool up. And save up for the AP, I have one for sale btw. Good luck and have fun. Link to comment Share on other sites More sharing options...
wwaitt05gt Posted October 28, 2010 Share Posted October 28, 2010 very helpful i have an 05lgt too and was curious what to mod first, thanks guys Link to comment Share on other sites More sharing options...
GotTurboWut Posted October 28, 2010 Author Share Posted October 28, 2010 Oil pickup tube is faulty? Anyone on here w/ '05 GT's had that issue? I've done some searching and only found a handful... Link to comment Share on other sites More sharing options...
05LGTLtd Posted October 28, 2010 Share Posted October 28, 2010 It's not a "widespread" problem, but catastrophic if it happens to your engine. Killer B pick up tube and be done with it: http://www.killerbmotorsport.com/index_files/UltimateOiPickup.htm $200+labor for a pick up and you don't have your car for a few hours, or $2000 for a short block + labor and you will be lucky to have your car back in a week... But it probably won't happen to your car. By time you see the oil light flicker it's most likely too late. All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
