ColoSoca Posted June 27, 2016 Share Posted June 27, 2016 Hey all, Yesterday when trying to remove my uppipe I accidentally snapped one of the bolts connecting the uppipe to the exhaust manifold. Below is a picture of the other extremely rusty one... You can see why it broke. I need 2 new ones. Does anyone know this part number? Link to comment Share on other sites More sharing options...
whisky Posted June 28, 2016 Share Posted June 28, 2016 Are you sure that is the uppipe bolt? That doesn't look the bolts that were on my uppipe (which I just swapped a couple weeks ago) but perhaps we have different models or either mine or yours had been replaced with a different set-up at some point. Link to comment Share on other sites More sharing options...
hybridandy Posted July 1, 2016 Share Posted July 1, 2016 That's one of the doughnut flange bolts that connect your downpipe to your cat. If that's holding your up-pipe to the manifold, there's something very wrong going on. I recently reinstalled my OEM up-pipe and had those bolts snap when trying to remove the downpipe to make room. I bought a replacement pair at Advanced Auto but end up reusing the original rusty spring with the new nut and bolt. The new bolt came with a new spring (which was slightly longer than the old one but might just be the old one has compressed over time) but I couldn't squeeze it enough by myself under the car and also start the nut. It's held fine since. Link to comment Share on other sites More sharing options...
