waverunner Posted May 24, 2007 Share Posted May 24, 2007 I just wanted to let all the 5eat guys,i am one too,that amsoil atf is now available for our trannys. i spoke with company today and my friend told me that the atf had been reformulated back in december 2006 and was now approved to be used in our subarus,the addition of the atf now being available+ a tranny cooler could really be some good news! should bring down tranny temps alone and even more with cooler. let me know if i can help anyone interested. Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted May 24, 2007 Share Posted May 24, 2007 That's good news, I currently use Amsoil motor oil with good results (AFAIK), but I'd want to hear from SoA (in writing, preferably) that the Amsoil ATF is O.K. to use. YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
Jim_KT Posted May 24, 2007 Share Posted May 24, 2007 ^^^^^^^^ +1 Link to comment Share on other sites More sharing options...
jazzymt Posted May 24, 2007 Share Posted May 24, 2007 Two things I do not take a gamble with: 1) Subaru Coolant 2) Subaru ATF Would love to hear otherwise from Subaru though... [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
jerseyglock Posted May 25, 2007 Share Posted May 25, 2007 Amsoil has been in my 5EAT after IPT rebuild it, thats with TCU and valve body. Link to comment Share on other sites More sharing options...
VTGT Posted May 25, 2007 Share Posted May 25, 2007 I just wanted to let all the 5eat guys,i am one too,that amsoil atf is now available for our trannys. i spoke with company today and my friend told me that the atf had been reformulated back in december 2006 and was now approved to be used in our subarus,the addition of the atf now being available+ a tranny cooler could really be some good news! should bring down tranny temps alone and even more with cooler. let me know if i can help anyone interested. What are the intervals when changing this fluid according to amsoil? One more question what would actually create lower tempratures, the oil of the cooler? and since it is now ok does that mean warranty will not be comprised with using non-subaru ATF? Link to comment Share on other sites More sharing options...
wukindada Posted May 25, 2007 Share Posted May 25, 2007 I'll be picking some up @ years end along with a few more filters.....with ATF fluid I change every 16-17k for me regardless if it needs it or not. Cheap insurance IMO;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
waverunner Posted May 25, 2007 Author Share Posted May 25, 2007 OK, .first of all the temps are going to be lower because there will be less friction,the result is going to be lower temperatures,by adding a tranny cooler,(optional) it will help lower them even more. this will not void your warranty on your tranny because the atf meets and exceeds the performance specifications required by subaru think of it like this motor oils are different,but they all have to meet certain specifications so you can use any type of motor oil that you choose as long as it meets the specs.subaru does not tell you to use a specific type of motor oil or else we will void your warranty.bottom line if it meets their specs then it is perfectly safe to use with no fear of voiding your warranty. as far as intervals,which i dont agree with amsoil recommends 50,000 miles intervals under severe conditions or 100,000 miles under normal conditions, myself i will not ever go over 20,000 on the tranny. the amsoil tranny filter is also the same filter used as the oil filter on our cars which means you get the nanotech filter for your transmission too. i hope this helps explain things a little, believe me as soon as i went stage 2.5 last year i am looking for things to make my car last as long as possible. Link to comment Share on other sites More sharing options...
VTGT Posted May 25, 2007 Share Posted May 25, 2007 ok sounds good. Link to comment Share on other sites More sharing options...
waverunner Posted May 25, 2007 Author Share Posted May 25, 2007 I hope i explained this in as simple terms as possible. i actually thought that more people would be interested to see we actually have another option available now. perhaps i should have put this over in turbo powertrains. perhaps someone can move this thread ,might help Link to comment Share on other sites More sharing options...
subie_dude05 Posted May 27, 2007 Share Posted May 27, 2007 amsoil....royal purple...redline, which one would be the best for a 5eat? i know its a loaded question...but just wondering overall opinions. i was thinking about trying the royal purple since i use the oil..... Link to comment Share on other sites More sharing options...
waverunner Posted May 28, 2007 Author Share Posted May 28, 2007 To the best of my knowledge amsoil is the only one of the three that you mention that makes atf formulated for the automatic tranny. if the others dont meet the specs required by subaru then it may affect your warranty,if you have any trouble.royal purple is about one of the worst oils IMHO that anyone can use,and im not just saying that cause i use amsoil either.if i can figure out how to get it on here rp finished 5th out of 8 oils independently tested in the four ball bearing test for scarring. pennzoil platinum was 2nd rp finished behind quaker state Link to comment Share on other sites More sharing options...
VTGT Posted May 28, 2007 Share Posted May 28, 2007 Just curious but can you ballpark how much it decreases the tranny temperature? Also if a gas station is an amsoil dealer do you think they have this new ATF yet? Link to comment Share on other sites More sharing options...
waverunner Posted May 29, 2007 Author Share Posted May 29, 2007 VTGT, just a estimate now but from what i have read it is not at all uncommon to have a 20-30 degree temp drop in trannys,some have even had as much as a 40 degree drop,but i would say at least 20-25 degrees. i dont know what kind of tranny fluid the gas station is carrying or how long it has been stocked there,shoot me a line and let me know what they are gonna charge you and i will cut you some slack if at all possible. dont let them rip you off,i only am doing this amsoil to make a few pennys at best i wont rip no one off,you guys have been good as gold whenever myself or someone has had a question,only hope to return the favor. Link to comment Share on other sites More sharing options...
wukindada Posted May 29, 2007 Share Posted May 29, 2007 Subie....... You really do need to walk away from the purple blood;):( Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 29, 2007 Share Posted May 29, 2007 OK, stupid question time...f/r diffs and a/t fluids should realistically be changed at what levels? Link to comment Share on other sites More sharing options...
wukindada Posted May 29, 2007 Share Posted May 29, 2007 Depends @ what mod level you are @......... Stage II+ it's a good idea to change every 18-20K....f/r diffs every other time I am sure there will be lots of opinions on this one but I consider it cheap Ins. Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 29, 2007 Share Posted May 29, 2007 Depends @ what mod level you are @......... Stage II+ it's a good idea to change every 18-20K....f/r diffs every other time I am sure there will be lots of opinions on this one but I consider it cheap Ins. I Assume (uh oh) that when you say every other time you mean every other oil change? If so is $40 a diff reasonable (to have it done)? Link to comment Share on other sites More sharing options...
jazzymt Posted May 29, 2007 Share Posted May 29, 2007 $40 a diff is high if you're talkin dino oil. Full synthetic gear oil (75W-90) for the diffs is about $10 a quart & together, they total less than 3 quarts. Changing the oil in them is also just as easy as a regular oil change - except there's no filter, so it should be faster/easier/cheaper. FWIW - I've been stage 2 for 20/30k of my car's mileage & just did the 30k maint. The rear diff oil was fairly dark - needed to be changed, but the front oil wasn't too bad. I think what he meant was drain & fill the trans pan every 15-20k miles (3.5 quarts outta the total 9.8) and change the diff oils every other trans change (every ~30-40k miles). I'm working on a 30k maint. thread for automatic transmissions over on subaruoutback.org - if I ever finish it, I'll probably cross post the whole thing over here. You can take a look if you want to do it yourself - it's really just as easy as a regular oil change. http://www.subaruoutback.org/forums/showthread.php?s=&threadid=8515 [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
Effin Ponderous Posted May 29, 2007 Share Posted May 29, 2007 Thanks guys... Link to comment Share on other sites More sharing options...
VTGT Posted May 29, 2007 Share Posted May 29, 2007 I might have to get them to flush and refill my tranny fluid with amsoil on my next oil change. I only have around 16k is that too early? Link to comment Share on other sites More sharing options...
jazzymt Posted May 29, 2007 Share Posted May 29, 2007 That's pretty early for a full flush. Recommended maint. is to flush at 60k & although my ATF was somewhat brown at 30k, it certainly was ok. [CENTER][URL="http://legacygt.com/forums/showthread.php?t=18504"]Subaru Plug & Play Aux-in Mod[/URL][/CENTER] [CENTER][URL="http://www.jazzyengineering.com"]www.jazzyengineering.com[/URL][/CENTER] Link to comment Share on other sites More sharing options...
wukindada Posted May 30, 2007 Share Posted May 30, 2007 ATF fluid every 18-20k......F&R diff every 36-40k Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
VTGT Posted May 30, 2007 Share Posted May 30, 2007 ATF fluid every 18-20k......F&R diff every 36-40k So you think 16k is too premature to switch over to amsoil.... Link to comment Share on other sites More sharing options...
wukindada Posted May 30, 2007 Share Posted May 30, 2007 A little early but it still cannot hurt;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
