Bilstein HDs for non-Spec.B - what top hats?
DeltaNu1142
OK... I'm considering going back to Bilstein HDs & mild lowering springs after a short (but fun) stint with coilovers. I'm wondering where people get tophats. I have a few older ones sitting around installed on stock suspension, but I think I'd rather buy new. So where do you get them? What do you go with?
Tits mcgee
I have coilovers right now. I don't have top hats, unless I want to dismantle the complete stock suspension set I have for return-to-stock (some day).
Can't use OEM LGT top hats? That's not what the site vendor is saying. I wanted to go with HD's because I had them before & loved the ride... just not the height. With the Spec.B hats, the front was way up in the air.
Sell me on Konis. I can get HD's new for <$600, but I want a level ride height.
Tits mcgee
Hmm. Sorry for the slight hijack, but will Spec.B tophats work on stock springs? I was going to send my Bilstein's in for a rebuild and have some stock struts, but no tophats for them....
2013 S4 - Glacier White - DSG - B&O - Tech Package - Sports Diff - Napa - RS4 Grille - Stasis Exhaust - APR Intake - KW Variant 1 - Stern Control Arms - CR-15 - Stasis RSB - Moog Endlinks - PC Hyper Black Peelers - Deval Front Lip - ECS Rear Diffuser - Carbon Imports Ducktail - ECS Mirror Caps - Relak Paddle Extensions - Autostyle Floor Mats - LED Interior - V1 - Blackvue DR900s -
[sIGPIC][/sIGPIC]
You have to use spec b tophats with any bilstein shock, including HD's. period.
you can get koni's for under $600 as well and you dont have to source tophats. just take apart your stock setup. And they are adjustable and better with aftermarket springs. as they use the standard LGT format so springs desighend for the regualr LGT setup will work as intended instead of the ride height being off perhaps.
they may, but the ride height will be off as spec b springs are slightly shorter in the front. you may need some spacer washers so you dont run out of thread when you put the top nut on the shock.
Oem tophats can be had for cheap. why take the chance of there being a problem.
OK, OK, I'm warming up to the idea... the question remains, though: sure, I can get OEM top hats from the dealer, but is there a better quality or cheaper option?
ther are some other vendors that sell tophats with stiffer rubber or more caster/camber built in to them, and even full pillowball camber plates. what are you looking to get?
I don't need camber plates--but if I can get mild built-in camber, and a stiffer hat for the same or near the price of OEM pieces, why not, right?
Tits mcgee
I'm not running OEM spring - Swift sport springs on my Spec.B struts currently. Those springs will transfer over to the standard struts for about 4 weeks while Bilstein does the rebuild. If I have to get standard tophats too, I guess I can, but if the Spec.B tophats will work for the 4 weeks the Bilstein's are out getting rebuilt, I'll just to that way...
[sIGPIC][/sIGPIC]
ok, then whiteline has a product for you
the KCA409 is what you need. - http://www.whiteline.com.au/product_detail4.php?part_number=KCA409
the centers are offset so you can gain caster and camber depending how you orient them.
http://www.whiteline.com.au/images/products/KCA409.jpg
