Shotokan1509 Posted November 18, 2011 Share Posted November 18, 2011 My passenger window track is f'ed... I popped the edges but can't get the center of the panel. Where are the hidden screws? 2005 Link to comment Share on other sites More sharing options...
Drift Motion Posted November 18, 2011 Share Posted November 18, 2011 there are some screws by the door handle, and the door release, rest should just be all pop it Link to comment Share on other sites More sharing options...
Shotokan1509 Posted November 20, 2011 Author Share Posted November 20, 2011 Hmm I looked around door handle, didnt see any or any concealers of them, does the entire handle pop out? Link to comment Share on other sites More sharing options...
Boulderguy Posted November 21, 2011 Share Posted November 21, 2011 UNDER the door handle trim, pop it off from the bottom with a screwdriver. Link to comment Share on other sites More sharing options...
phenryiv1 Posted November 21, 2011 Share Posted November 21, 2011 The door handle on the 05-09 Legacy is the spawn of the devil. Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
LegacyKid5 Posted November 23, 2011 Share Posted November 23, 2011 From what I remember, there is one under the actual door handle lever, you have to pop of the plastic plate covering it, pop of the black triangle plastic piece in the front corner of the door, and then remove the top plate of the door handle, and there is screws below it. Relatively easy once you know where everything is. This thread helped me a ton, check it out: http://legacygt.com/forums/showthread.php/door-panel-removal-sound-deadening-install-pics-20069.html?t=20069&highlight=door+panel Link to comment Share on other sites More sharing options...
Shotokan1509 Posted November 25, 2011 Author Share Posted November 25, 2011 From what I remember, there is one under the actual door handle lever, you have to pop of the plastic plate covering it, pop of the black triangle plastic piece in the front corner of the door, and then remove the top plate of the door handle, and there is screws below it. Relatively easy once you know where everything is. This thread helped me a ton, check it out: http://legacygt.com/forums/showthread.php/door-panel-removal-sound-deadening-install-pics-20069.html?t=20069&highlight=door+panel Perfect! That is exactly what I was thinking, but was afraid to start prying random spots against clips the wrong way and snapping them Link to comment Share on other sites More sharing options...
