bcmaxx Posted February 21, 2014 Share Posted February 21, 2014 So I've installed guages in Imprezas, and there is always somewhere to put them. My 92 legacy , not so much. and I'd rather not run a universal a pillar setup- I have one in my jeep and it's annoying. Where can I put my gauges? I have 2, a a/f meter and a boost gauge both 2 5/8 Link to comment Share on other sites More sharing options...
monkeyposeur Posted February 21, 2014 Share Posted February 21, 2014 I put mine on the dash for simplicity. Not the cleanest look. Lots of people put them on the steering cowl behind the steering wheel. Another place is to put them in the blank spot next to a single din radio. Others put them in the glove box since they don't really need to look at them all the time but I like being able to see them. I haven't installed an AFR in the tleggy though. Link to comment Share on other sites More sharing options...
Bdubs Posted February 23, 2014 Share Posted February 23, 2014 I put my boost gauge under the ashtray near the shifter. I have an auto, and I don't smoke so it's out of the way. It is a bitch to look at it while driving? Kind of. I put it down there so it wasn't so obvious to a would be thief. Link to comment Share on other sites More sharing options...
bcmaxx Posted March 13, 2014 Author Share Posted March 13, 2014 http://i232.photobucket.com/albums/ee110/bcmaxx/20140312_164447_zpsf8957132.jpg Wife hates. Works for me...keeps them of the dashtop and away from the center console Link to comment Share on other sites More sharing options...
USLiberty Posted April 2, 2014 Share Posted April 2, 2014 I used some either pvc pipe or an extension pipe from a shop vac, forgot exactly... but the 2-5/8" gauge fit nice and tight. I cut it with a sawzall and a file to fit flush to the pillar post. I bent up a steel strap for a little infrastructure, then I riveted to the pvc pipe and then to the pillar. Then some epoxy to seal the corners and paint, I like being able to watch my AFR's while I tune for max gas mileage on the fly. Some nice scenery of Sedona, AZ in this pic also. Our winter has been nice, usually there's some snow this time of year. http://i1065.photobucket.com/albums/u386/onefastlt/IMG_20140323_122452_zpse3289ce0.jpg Link to comment Share on other sites More sharing options...
BiNiaRiS Posted April 5, 2014 Share Posted April 5, 2014 This is my setup. I plan on adding one matching boost gauge on the bottom. Or adding an oil temp down below and getting a nicer boost gauge up top. http://i.imgur.com/WCIrk7kh.jpg Link to comment Share on other sites More sharing options...
monkeyposeur Posted April 5, 2014 Share Posted April 5, 2014 ^Wow! One of the nicest set ups I have ever seen. Link to comment Share on other sites More sharing options...
BiNiaRiS Posted April 5, 2014 Share Posted April 5, 2014 ^Wow! One of the nicest set ups I have ever seen. The downside is losing the upper two vents. If you have A/C and live in a warm area that might be a hard sale. otherwise it allows for a lot of space. For heat I usually have the bottom vents on so it works well for me. Either way the bottom gauge placement works amazingly well. Link to comment Share on other sites More sharing options...
USLiberty Posted April 5, 2014 Share Posted April 5, 2014 The downside is losing the upper two vents. If you have A/C and live in a warm area that might be a hard sale. otherwise it allows for a lot of space. For heat I usually have the bottom vents on so it works well for me. Either way the bottom gauge placement works amazingly well. It doesn't cover any vents, it attaches to the a-pillar plastic. I use AC a lot Link to comment Share on other sites More sharing options...
BiNiaRiS Posted April 5, 2014 Share Posted April 5, 2014 It doesn't cover any vents, it attaches to the a-pillar plastic. I use AC a lot eh? i didn't quote you. i was talking about my setup. Link to comment Share on other sites More sharing options...
