e_NiNo Posted July 26, 2011 Share Posted July 26, 2011 https://fbcdn-video-a.akamaihd.net/cfs-ak-snc6/232075/315/10150241964660981_35842.mp4?oh=5cec3a09682bb664857635a9407c33a7&oe=4E30BB00&__gda__=1311816448_96a44d418b33275190190b45c44cf76c Scuse for the link, I hope you have acces, it's on my Facebook page... When I push the clutch the toc toc are never there I suspect a **** with the dual mass flywheel !!??? Link to comment Share on other sites More sharing options...
AShoe Posted July 26, 2011 Share Posted July 26, 2011 If the noise goes away when you press the clutch I would suspect TOB. It might be just a loose bolt on the slave cylinder or something like that too. Link to comment Share on other sites More sharing options...
e_NiNo Posted July 26, 2011 Author Share Posted July 26, 2011 TOB ? Scuse I am french But have this sond sometime only, and the dealer change at 2 times my short bloc ( I suppose he remove the clutch and replace it at the same time...) Link to comment Share on other sites More sharing options...
dudeondacouch Posted July 26, 2011 Share Posted July 26, 2011 TOB = Throw-Out Bearing Link to comment Share on other sites More sharing options...
e_NiNo Posted July 26, 2011 Author Share Posted July 26, 2011 He have 260 miles the dealer replace it last monday at the same time he rebuilt my 2 heads... It's not the TOB Link to comment Share on other sites More sharing options...
PaulFWMotorsports Posted July 26, 2011 Share Posted July 26, 2011 Wow....260 miles on a new motor?? That's gotta be some sort of record. On my Android it sounds like a rod knock. Link to comment Share on other sites More sharing options...
e_NiNo Posted July 26, 2011 Author Share Posted July 26, 2011 Yes but when I puch the clutch the sond stop ... A rod knock do the same think? And it's intermitent Link to comment Share on other sites More sharing options...
frank_ster Posted July 26, 2011 Share Posted July 26, 2011 rod knock does not stop when you press the clutch. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
MasAyinde Posted July 26, 2011 Share Posted July 26, 2011 Perhaps an issue with an axle? Link to comment Share on other sites More sharing options...
PaulFWMotorsports Posted July 26, 2011 Share Posted July 26, 2011 rod knock does not stop when you press the clutch. Listening to this sound on my pc didn't help; my hearing ain't what it used to be. However, we've had two Subarus come in with rod knock that was initially mis-diagnosed as clutch related as the sound went away when the clutch pedal was depressed. Could also be a chipped tooth in the gearbox; we've experienced that as well on a few Subarus. Link to comment Share on other sites More sharing options...
