firehawk618 Posted August 22, 2014 Share Posted August 22, 2014 I believe my rear differential is telling me it's time for some attention. I have replaced both rear wheel hubs/bearings within the last 2 months. I drained the fluid *SO NASTY* and replaced it. I don't think it has ever been changed. There was a bit of metal sludge build up on the drain plug. It hooowwwwllllllll's when decelerating. Never when accelerating and pretty quiet when cruising. I think I'm going to start shopping for a used carrier unless anyone on here has had a GOOD experience with rebuilding this carrier. Also, exactly what model is it? I believe mine is going to be a 3.27 ratio from what I have researched but have not found a definitive answer to exactly what model this is. Thanks for any good advise. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
08 LGT Posted August 22, 2014 Share Posted August 22, 2014 Mileage? And by "decelerating" do you mean while gradually slowing down while coasting, or when you are applying the brakes? Link to comment Share on other sites More sharing options...
Max Capacity Posted August 22, 2014 Share Posted August 22, 2014 When I needed to replace mine, I googled used r-160 rear diff subaru legacy. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MrTris Posted August 22, 2014 Share Posted August 22, 2014 Isn't our FD 4.11? It should have a 4.111 sticker on the back, right? Link to comment Share on other sites More sharing options...
firehawk618 Posted August 23, 2014 Author Share Posted August 23, 2014 Mileage? And by "decelerating" do you mean while gradually slowing down while coasting, or when you are applying the brakes? When gradually decelerating. Almost "floating" if that makes sense. If I take my foot off the throttle it stops. If I accelerate it stops. I guess now that I think about it, it does it when coasting at almost no load. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
firehawk618 Posted August 23, 2014 Author Share Posted August 23, 2014 Auto 05-06 LGT is 3.27 from what I have read. OBXT is a different ratio. Correct me if I'm wrong. This is what I found online: Outback, 2.5L (4 cyl), turbo, AT (3.59 ratio) Outback, 2.5L (4 cyl), w/o turbo; Limited, AT (4.11 ratio) Outback, 2.5L (4 cyl), w/o turbo; Limited, MT (4.11 ratio) Outback, 2.5L (4 cyl), w/o turbo; exc. Limited; AT (4.44 ratio) Outback, 2.5L (4 cyl), w/o turbo; exc. Limited; MT (4.11 ratio) exc. Outback; (2.5L, 4 cyl), turbo, AT (3.27 ratio) exc. Outback; (2.5L, 4 cyl), turbo, MT (4.11 ratio) exc. Outback; (2.5L, 4 cyl), w/o turbo; Limited, AT (4.11 ratio) exc. Outback; (2.5L, 4 cyl), w/o turbo; Limited, MT (3.90 ratio) exc. Outback; (2.5L, 4 cyl), w/o turbo; exc. Limited; AT (4.11 ratio) exc. Outback; (2.5L, 4 cyl), w/o turbo; exc. Limited; MT (3.90 ratio) Outback, 2.5L (4 cyl), turbo, MT (4.44 ratio) Outback, 3.0L (6 cyl, AT, 3.27 ratio) 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
08 LGT Posted August 25, 2014 Share Posted August 25, 2014 It might be something wrong with the way one (or both) of the wheel hubs were installed then. That sounds like exactly what my car felt/sounded like when my rear hubs/bearings started going bad - the sound and vibration went away under acceleration and when breaking, but was very noticeable when coasting. Link to comment Share on other sites More sharing options...
firehawk618 Posted August 25, 2014 Author Share Posted August 25, 2014 I replaced both rear hubs not long ago. I don't see a whole lot that can go wrong with installing them as they're a sealed unit. Removing them, now that's another story. Really easy to ruin them removing them. 10' CTS-V, A6, Airraid, 2.4 upper, ID850's, self tuned. SOLD:06' LGT Wagon. BNR16G, Catless UP, DOWN, Hexmods VB, Hexmods diff bushings, BIG TMIC. Best 0-60: 4.651 by AP 1/4= 13.678@100.73 mph, 1.945 60', Automatic transmission. Link to comment Share on other sites More sharing options...
