05sleeper Posted March 12, 2013 Share Posted March 12, 2013 I've followed Cobb instructions and it still won't freaking read ecu! It says "a cable was found, but an ecu was not detected. Please check cabling and cycle key ignition if needed" I have the access port hooked up to the obdII plug and then USB from access port to computer. Then I have LC-1 tuning cable to a serial to USB cable to computer. I've checked the configuration in ATR and it keeps saying I need a Cobb cable? Someone please enlighten me so I can get the f#*%er tuned already. Thanks Link to comment Share on other sites More sharing options...
05sleeper Posted March 12, 2013 Author Share Posted March 12, 2013 Had an Ebay vag com cable and it worked for connecting ecu but still won't show anything for the LC-1 connection. Downloaded Romraider to see if I could just log with that and apparently I have to download other files with it that I can't find or figure out. About to say screw it and take it to a tuner and have them deal with it Link to comment Share on other sites More sharing options...
SkateAndDestroy Posted March 12, 2013 Share Posted March 12, 2013 What operating system on your laptop? Once I went to Windows 8, I had to buy a need serial adapter cable to get my wideband to log. Link to comment Share on other sites More sharing options...
05sleeper Posted March 12, 2013 Author Share Posted March 12, 2013 It's windows 7 and everything is updated. Log works reads the wideband fine just won't connect to atr Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted March 12, 2013 Share Posted March 12, 2013 Check the 2.5mm cable going to the computer where it connects to the LC1 out. It might seem like it clicks in but I had to cut some excess plastic on the LC1 out cable so the 2.5 would actually go in and connect. Link to comment Share on other sites More sharing options...
