gimpydingo Posted May 15, 2015 Share Posted May 15, 2015 So my UP heat shield is all loose. I tried wiring it up to hold in place, but it still shifts and I see some "knock" in all areas of my LV. Had been clean for the past several months. Maybe one are would show a bit, but not return. Doesn't look like I could clamp the ends to hold it on. So... Easy way to remove while still in place? Or shall I (do I have to) remove the UP to get that sucker off there? I know I'll have to wrap it after. Thanks as always. Link to comment Share on other sites More sharing options...
GTTuner Posted May 15, 2015 Share Posted May 15, 2015 Try a couple of exhaust clamps that will actually "crush" the shield a bit and hold it in place without rattling. Just a suggestion that may save you some time. Link to comment Share on other sites More sharing options...
gimpydingo Posted May 15, 2015 Author Share Posted May 15, 2015 Ahhhh to crush it down... I like it! Link to comment Share on other sites More sharing options...
GTTuner Posted May 15, 2015 Share Posted May 15, 2015 Its a bit tight in there.......and you will ultimately have to remove the pipe to get the shield off and do a quality job wrapping the pipe. So why not try? Good Luck! Link to comment Share on other sites More sharing options...
gimpydingo Posted May 15, 2015 Author Share Posted May 15, 2015 Yep, worth it for the moment. On a side note need to make a turbo blanket as well. Got the materials, just need to measure the shape/size of the turbo with some paper and start cutting/sewing. Link to comment Share on other sites More sharing options...
gimpydingo Posted June 30, 2015 Author Share Posted June 30, 2015 Just an update. I did get an exhaust clamp on the bottom of the heat shield and got it crushed down. Seems to be solid. Thanks! Link to comment Share on other sites More sharing options...
