Banjo bolt won't budge!!
I hate to be that guy to say this but just make sure youre turning it in the correct direction, counter clockwise. As a automotive teacher I see this mistake made daily and thought I would throw that out there. If you are turning it counter clockwise and it's not coming off I would soak it in PB blaster as previously stated and find a way to extend your wrench to increase your leverage also as previously stated. If those do not work a little heat from a tourch may be needed. Good Luck!
Oh that washer sucks. Getting it off is easy, putting it back on was just stupid. Wound up having to use a string to dangle the washer into the area in order to install it. That area has NO space...
A cool trick that you can use in the future is apply a litte grease or a dab of silicone to help hold the washer in place while you install it.
