tofuman924 Posted September 4, 2011 Share Posted September 4, 2011 i have been searching the forums on how to install the rear license plate light on a 06 sedan and i didnt have any luck on it. Im sure its been cover but i just cant find it would be nice if someone linked me one or something. Weird that the license plate light cover wasn't a screw on... Link to comment Share on other sites More sharing options...
mk6933 Posted September 5, 2011 Share Posted September 5, 2011 You won't be able to pop out any covers. You will need to remove your trunk liner or stick your hands on the side of the trunk liner and reach in and twist the adapter for the bulbs. Link to comment Share on other sites More sharing options...
Aken Posted September 5, 2011 Share Posted September 5, 2011 Six pop tabs, two rubber stoppers and the ring around the trunk release handle later, and you can access the license plate bulbs! Link to comment Share on other sites More sharing options...
xero287 Posted September 5, 2011 Share Posted September 5, 2011 ^+1 Link to comment Share on other sites More sharing options...
robitrice Posted September 5, 2011 Share Posted September 5, 2011 take one beer and about 30 mins depending on the size of ur hands. Link to comment Share on other sites More sharing options...
Code Posted September 5, 2011 Share Posted September 5, 2011 Or remove the two bolts behind the lic. Plate. Pop off lower portion trunk exterior. Pop off exterior light housing. Replace bulbs. Snap it all back together. Enjoy. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
mk6933 Posted September 5, 2011 Share Posted September 5, 2011 I never pop the tabs off. I just stick my hands through the side of the liner and reach in. Link to comment Share on other sites More sharing options...
charlie_sheen Posted September 6, 2011 Share Posted September 6, 2011 1. Remove license plate. 2. Remove two 10mm bolts underneath. Rear panel pops off, pull firmly. 3. Pull down black plastic light surround piece. 4. Twist each light counterclockwise. 5. If you need help from here, you're special. I did it last week, took 10 min tops great finishing product. Link to comment Share on other sites More sharing options...
tofuman924 Posted September 6, 2011 Author Share Posted September 6, 2011 thank you guys so much for the feed back it is really helpful for a noob like me. i will be doing it this weekend Link to comment Share on other sites More sharing options...
Nrw Posted September 6, 2011 Share Posted September 6, 2011 Or remove the two bolts behind the lic. Plate. Pop off lower portion trunk exterior. Pop off exterior light housing. Replace bulbs. Snap it all back together. Enjoy. Just don't do that in zero degree weather Link to comment Share on other sites More sharing options...
cwindle07 Posted April 14, 2012 Share Posted April 14, 2012 I just upgraded the license plate lights to LEDs, and going through the trunk exterior panel was pretty easy. But, it definitely made some scary sounds:icon_roll Link to comment Share on other sites More sharing options...
