4eat slipping junk yard crap issues
so ive had a lot of bad crap happen with my lego wagon
3rd trans was great
got from a kid who went 5spd
had a shift kit in it
but went on a trip for 3 hours straight and almost to wifeys aunts
kid in the back and BOOM
and no 4th/3rd whatever it is and no reverse
found that after pulling in to a gas station
and couldn't back up
only luck was a friend with a trailer was just happen to be coming to the area the next day
and more crap it barely fit on it had to go over the wheel hump so my hitch chain holder snapped had to jump through window
and pulled the ebrake before it hit a power pole
so anyways more bad
had my dad help get another trans
he found one in a junk yard
they said was great
well got it in and went to fix oil leaks and coolant
and had a cam slip took a huge chunk outa my finger
and well got some good heads(gigity)
and started to put them on to find my torque wrench was bad
and stripped the block hole
so ya great times got some money from grandma passing so I got a jdm motor
and its great
just to find my trans slips horribly 1st to 2nd
and had a torque bind on turns
so I took the rear off the old trans
and swapped it out
the torque bind is gone but the slip is just horrible still
and went to a buddys and it slipped in park on a slight hill
but cant find the info on whats going on
I saw it somewhere but no luck finding it
any help would be great
and yes the at temp light flashes 16 times and havnt gone into the codes yet
having a lil gremlin(kid almost 2)monster) takes a lot of my time
helppppppppppppppppp.
I just want to swap to 5spd but no funds for that yet
so somehow gotta figure a way to fixish this one
have parts from other trans
3rd trans was great
so anyways more bad
they said was great
and its great
and swapped it out
and swapped it out
THE PARKING ''PAWL'' IS MESSED UP.
THIS IS A COMMON ERROR WHEN REMOVING THE REAR SECTION OF THE AUTO TRANS.
(sorry for the caps.)
but i think your ATF level is low.
and the damage may be permanent.
if you have installed 3 auto trans and all 3 have had problems,
you are doing something wrong.
this will tell you what is wrong with the electronics in your trans.
sooner is better than later.
PS: HOW ABOUT USING SOME PUNCTUATION,
PLEASE?
:):jedi:im writing on a mini lab top so bare with me. thanks for reply.
I know how to change a trans out.;)
when I got the car the trans was bad slipping like it is now but the last one was awesome:cool: but the prob with it was the pan was glued on with some crazy stuff that I couldn't get the off with out bending and scratching the hell outa the trans so I put an external filter and ran great till the 3 hours straight then boom felt like getting hit by something.
so now this one.
:confused:I don't see how I messed up when I swaped the rear it was just pull off and put on essentially and after I did it the turning torque bind was gone and just slips hard 1st to 2nd.
:spin:I have parts from old trans any way I can look through it and find good parts and make a good one.
:bbq:I think the old trans only had the issue with the 4th and reverse clutches?
the parking pawl is the catch that locks on a cog to keep the gears from turning,
it is what makes ''park'' work.
there is a spring in the rear extension housing that keeps the pawl in place.
if the spring is dislodged the pawl will nor engage, no park.
google, subaru parking pawl.
it goes into park normally but on a slight hill it was slipping back.
adjust the selector or you sayin I gotta take the back piece off again and check the spring.
im losing my mind chasing demons on this car I love it but damn shoulda never let the wife decide manual or auto cuz to find out later that she could drive stick since she works for xbox and they have the simulator that shes well versed in soooooooo ya as soon as I can no more auto
im gonna hopefully take a look at it this weekend
thanks both of ya
and can someone take a pic of a trans stick next to a oil stick my dumbass left it under the hood and lost it but had an extra oil stick trimmed it alil and seems to be where it shoulda been. I know somewhere in my mess of a garage(destroyed since the start of this non stop crap) I have an extra stick but yet to find it
ok so I played with the safety switch and it seems to drive a lot better but didn't drive far since ive been drinken again:cool:
but also put in some really nice green hoeses ;p :spin:
and had to trim alil header wrap back since I leaked trans fluid on it and it just kept smoking wifey kept complaining(her moms vanagon caught fire when she was a kid):p
I found this diagram. Maybe it will help. It's from a later model but it looks to be the same. I don't remember messing with the stopper pin and maybe that's why mine is still out of adjustment. My SS has a turbo so the downpipe is in the way of the switch so I have to pull it to adjust it again.
Also I found this text (there are no diagrams with it) again: "Some 2005-08 Legacy, Outback, Impreza and Forester models with the 4EAT automatic transmission may turn on the MIL and store DTC P0851 and/or P0852 in computer memory. One likely cause for the code(s), reports Subaru, is a misadjusted inhibitor (Neutral safety) switch and gearshift cable. Adjusting both components should turn off the light in a hurry. Here’s the drill:
Start by placing the gearshift lever in Neutral. Now loosen the three inhibitor switch attaching bolts. Using the left-hand illustration on this page as a guide, insert a stopper pin or brass drift into the holes in both the switch lever and body, as shown. Keeping the pin as straight as possible, tighten the switch attaching bolts to 30 in.-lbs.
Now move on to the gearshift cable adjustment. Using the illustration on the right for reference, loosen adjusting nuts A and B of the cable. Now tighten adjusting nut B until it just makes contact with the connector lever. Using a spanner wrench or similar tool to prevent nut B from rotating, torque adjusting nut A to 65 in.-lbs. The cable is now properly adjusted.
To complete the fix, check that the shift detents engage each gear smoothly, the starter turns in Park, the backup lights work in Reverse and the Park lock engages when the shift lever is placed in Park."
still shifts hard 1 to 2nd and worse when warmed up and now getting a
p0748 code
I just wanna kill somebody for making me stuck with a damned automatic,
my manual car had its issues sometimes but would still work even through one bad trans with seal leak just kept spraying brake cleaner once and awhile and kept going till I fixed it even when one bad gear could still power shift through it lol
but this damn automatic keeps me up at night trying to figure it out,
I have plenty of parts from the old trans.s
I wanna fix/rebuild the old one with shift kit until I get money again then swapping that crap for 5mt fml ftw
okay so I changed out the whole valve body hoping to get my shift kit one in and fix my problems but instead.
so now when I start to go it takes abit to go like its slipping till it catches but once going it seems great
ill have a more test drive 2mro so hopefully itll feel better and not boom
on start up it still flahes I just cant figure the secret handshake is there a plug ur suppose to put a wire in and ground it
ive looked and cant find a straight answer
ok looked alil and found some things about the trans codes being different and they are but how much different could it be
im losing my mind
I ripped the heart of the trans and put a pig heart and finally stitched it up it
now it walks like a slug and runs once going
