SSpeed Posted April 16, 2012 Share Posted April 16, 2012 Event: Dyno baseline - Dyno Dynamics dyno Location: The Boost Creep, Longmont, CO Date: 01/26/2011 Ambient Temp: 55deg Elevation: 56xx' Weather: Clear Car: 2005 Subaru Legacy GT Limited Tuner: Infamous Dyno Info: Dyno Dynamics 1.15 SAE Transmission: 5speed Gear: 3rd Peak Horse Power at RPM: 260.4hp @ 5560rpm Peak Torque at RPM: 300 ft lbs @ 3580rpm Baseline hp/tq for a stock on same dyno: 180ish, Stage2 was 217hp @ 4900rpm / 244.6 ft lbs @ 3500rpm Target Boost: 17.5psi Target AFR: Not measured SAE Correction factor: 1.15 Fuel: Winter 91 (Conoco) Engine/Power Modifications: - BNR 16g/VF40 (evo3 variant) - Infamous tune - PTP turbo blanket - One step colder plugs - Grimmspeed crossover pipe - Ported my own manifolds to match, just at the crossover pipe attachments - STI uppipe - Cobb catted downpipe cut to 3in flange (otherwise it narrows) - AVO mid/Y-pipe cut to 3in flange (otherwise it narrows) - Grimmspeed 3-port EBCS - Stock mufflers - Stock intake and filter - Stock intercooler (jbwelded) - AVO fuel pump - Autospeed external IC spray system that sprays when a set injector duty cycle and delta between ambient and back of IC temps are met Driveline Modifications: Southbend Stage3 organic clutch, ACT Streetlite flywheel Suspension Modifications: None Other Modifications: None http://i85.photobucket.com/albums/k62/dil222/BoostCreep16g115correctedsspeedresize.jpg http://i85.photobucket.com/albums/k62/dil222/BoostCreep16gboostandafrsspeedresize.jpg http://i85.photobucket.com/albums/k62/dil222/vf40vs16g.jpg This dyno: 260.4hp @ 5560rpm / 300 ft lbs @ 3580rpm, boost target of 17.5psi met at 3200rpm Stage 2: 217hp @ 4900rpm / 244.6 ft lbs @ 3500rpm Link to comment Share on other sites More sharing options...
LGT For ME Posted April 17, 2012 Share Posted April 17, 2012 Like the new thread SSpeed, dont have any new ones up but will have one soon w/ my V52 so until then lets see some other posts Link to comment Share on other sites More sharing options...
ragman Posted May 3, 2012 Share Posted May 3, 2012 Scott, where's your new dyno chart from last month? Link to comment Share on other sites More sharing options...
SSpeed Posted May 8, 2012 Author Share Posted May 8, 2012 I have to re-dyno now that I've fixed the issues... Link to comment Share on other sites More sharing options...
blongo804 Posted May 8, 2012 Share Posted May 8, 2012 Cool thread! Not bashing, but wondering why does the PSI curve goes up and down several times? Should it not be smooth? I don't know what i'm talking about..just wondering lol. Link to comment Share on other sites More sharing options...
SSpeed Posted May 8, 2012 Author Share Posted May 8, 2012 It should be smooth, however, on that graph you are looking at a variance of maybe .25 -.5 psi.. Link to comment Share on other sites More sharing options...
blongo804 Posted May 8, 2012 Share Posted May 8, 2012 Oh ok, that makes sense then. I didn't even think to look at the axis numbers. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 8, 2012 Share Posted May 8, 2012 That dyno reads wicked low, lol. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
SSpeed Posted May 8, 2012 Author Share Posted May 8, 2012 Ha ha, or we're 5800ft above sea level... Stage2 was 217hp here, stock 180ish... ;( Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 8, 2012 Share Posted May 8, 2012 Missed the elevation. That's not terrible, then. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Legend Posted May 9, 2012 Share Posted May 9, 2012 That dyno reads wicked low, lol. Yep, probably lowest dyno anywhere. I ran 12.9's on my 279whp VF52 setup at 5860' track elevation, so 300whp on this dyno equals mid 12's at sea level. My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
Lucid Posted May 9, 2012 Share Posted May 9, 2012 Curious why you dyno at Boost Creep and get etuned by Infamous. You're welcome to tell me to bugger off and that it's none of my damn business. Link to comment Share on other sites More sharing options...
SSpeed Posted May 9, 2012 Author Share Posted May 9, 2012 ^ $150 vs. $450 Link to comment Share on other sites More sharing options...
LGT For ME Posted May 10, 2012 Share Posted May 10, 2012 SSpeed arent you now tuned by Cryo/Dave, thought you were.... For those out there that dont know about Cryo he's the same price as infamous but much better support/turn times Link to comment Share on other sites More sharing options...
SSpeed Posted May 10, 2012 Author Share Posted May 10, 2012 I am now yep, first tune was by infamous... Dave/cryo now and he is awesome... Link to comment Share on other sites More sharing options...
chad12gt Posted June 18, 2012 Share Posted June 18, 2012 jb weld on IC? Where to do this? Apprec. info Link to comment Share on other sites More sharing options...
Zac88 Posted November 7, 2012 Share Posted November 7, 2012 more info on IC sprayer please! Link to comment Share on other sites More sharing options...
RallyMachine Posted November 7, 2012 Share Posted November 7, 2012 is this the first tune that was done on the car? i'd be interested in seeing that boost graph before and after the ebc/16g... Link to comment Share on other sites More sharing options...
SSpeed Posted November 7, 2012 Author Share Posted November 7, 2012 is this the first tune that was done on the car? i'd be interested in seeing that boost graph before and after the ebc/16g... The bottom overlay is the VF40 on stage2 vs the 16g tune. Remember that I'm a mile above sea level and numbers aren't going to look as good as those of you with nice dense air. Link to comment Share on other sites More sharing options...
SSpeed Posted November 7, 2012 Author Share Posted November 7, 2012 more info on IC sprayer please! Here ya go! http://legacygt.com/forums/showthread.php/need-help-wagon-owners-intelligent-intercooler-sprayer-99906.html?t=99906 Link to comment Share on other sites More sharing options...
mustangendsley Posted November 7, 2012 Share Posted November 7, 2012 my stage 2 is 233 hp and 260 tq. Not much diff than your 16g turbo, Im surprised you 16 g is not more. Im in colorado also. Link to comment Share on other sites More sharing options...
SSpeed Posted November 7, 2012 Author Share Posted November 7, 2012 You also have to consider type of dyno, temp of day tested, correction factor, etc. The 16g is still on stock fueling, you can't go much more than that. I've since added a PW intercooler and had Cryo tune it, don't have numbers for that yet. Link to comment Share on other sites More sharing options...
RallyMachine Posted November 7, 2012 Share Posted November 7, 2012 The bottom overlay is the VF40 on stage2 vs the 16g tune. Remember that I'm a mile above sea level and numbers aren't going to look as good as those of you with nice dense air. i saw that graph, but was wondering if you have a boost vs. rpm graph at stage 2. just curious to see how the spool changed and how much better boost was sustained to redline. anyway, you are running 10.5 afr, is that correct? Link to comment Share on other sites More sharing options...
SSpeed Posted November 7, 2012 Author Share Posted November 7, 2012 This isn't my current setup. On this dyno I was <10.5 AFR, boost tapering to 15.5 psi, target of 17.5psi. Currently I'm at 11.0 AFR, boost tapering to 17.5 I believe, target of 19.5psi. Haven't done a good dyno with that yet and I'm off my left foot again for another 3 weeks. The 16g could easily hold more out to redline if we wanted to, we just saw declining results after 17.5psi on the upper end of the powerband that we felt weren't worth pushing it on since I had stock fueling. Boost response followed the torque curve if you look at the overlay. I hit peak boost at nearly the same time as the VF40 did. The VF40, IIRC, held something like a measly 10.5psi to redline. Isn't Grand Junction at 4,500ft? Is that where you dyno'ed? I dyno'ed in Longmont at 6,600ft. That is a difference. What dyno did you dyno on and what was the correction factor? What was the temp of the day you did it? Link to comment Share on other sites More sharing options...
mustangendsley Posted November 7, 2012 Share Posted November 7, 2012 We have a awd dino here now at ASF. I will have to get the paper to look at the numbers. Link to comment Share on other sites More sharing options...
