dspl1236 Posted May 25, 2012 Share Posted May 25, 2012 ok i picked up a msd coil from summitracing. what are you guys doing for plug wires? custom or is there an oem option? Thanks Link to comment Share on other sites More sharing options...
dylandevine123 Posted May 25, 2012 Share Posted May 25, 2012 I have a thread a little ways down that answers this.... I looked at NGK's website and they have a nioce set for about $45. You can also go OEM. Link to comment Share on other sites More sharing options...
dspl1236 Posted May 25, 2012 Author Share Posted May 25, 2012 what about the coil end of the wires? the msd that is suggested has a 'normal' coil ends to it. what oem option fit these terminals? Link to comment Share on other sites More sharing options...
dspl1236 Posted May 25, 2012 Author Share Posted May 25, 2012 ok newer 2 phase wireset Link to comment Share on other sites More sharing options...
jayjay Posted August 1, 2012 Share Posted August 1, 2012 can someone please post pics or part #'s of the wire set to use with the msd coilpack, im confused which 1 to use. Link to comment Share on other sites More sharing options...
dspl1236 Posted August 1, 2012 Author Share Posted August 1, 2012 I think mine are from a 99. http://img.tapatalk.com/46c2043a-320f-82a3.jpg Sent from my VS920 4G using Tapatalk 2 Link to comment Share on other sites More sharing options...
twisty Posted August 1, 2012 Share Posted August 1, 2012 97 impreza has the cables you need. i found a set on a salvaged 1997 impreza wagon. they measured out to spec so i used them Link to comment Share on other sites More sharing options...
