lucasb4 Posted May 13, 2014 Share Posted May 13, 2014 have problems with my drivetrain (2000 jdm b4 twin turbo 75k) i thought it was the rear diff, have taken it off this evening, got about a litre of thick brown fluid out of it, was wondering if there is any way of knowing it the diff is ok or broken, it spins ok from the prop end and no bad noises or physical signs if damage other than the leaky seals, and also can i pop it open without problem and look inside it then reseal it? Any help appreciated, andy Link to comment Share on other sites More sharing options...
Max Capacity Posted May 13, 2014 Share Posted May 13, 2014 If they mount like 2005-2009's do you need to lower it from the chassis mounts to remove the cover. The dealer had a new metal gasket. Those top mount nuts can be a pita. Thick brown, yes the 75w-90 is pretty thick. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lucasb4 Posted May 22, 2014 Author Share Posted May 22, 2014 managed too get it off and stripped, cleaned up and remounted etc, not sure what fluid came out and what too put back in, is hard finding any info on a jdm twin turbo, also want too change gearbox oil but want to get it right, any ideas? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 22, 2014 Share Posted May 22, 2014 Ask one of the Mike's http://www.AZPinstalls.com or http://www.infamousperformance.net I'm sure one of them would know. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
