Pittcrew Posted April 25, 2013 Share Posted April 25, 2013 first off i just replaced my alternator and thats a breeze i hated the price though. but my driver window is now un responsive. i dont want to replace the motor in it right a way and find out thats not it. so anyone else have any other ideas what it could be or is it the motor? thanks for the help!!! Link to comment Share on other sites More sharing options...
Hemingway Posted April 25, 2013 Share Posted April 25, 2013 Have you checked the fuses? Pull the door switch unit and check continuity. Might be the switch. Link to comment Share on other sites More sharing options...
Pittcrew Posted April 25, 2013 Author Share Posted April 25, 2013 i havent had the time ill check them and then pull the switch to see thanks Link to comment Share on other sites More sharing options...
johnegg Posted April 25, 2013 Share Posted April 25, 2013 it is usually the switch in the door. if you wiggle it or press in on it you may find it works. this is a very common problem. Link to comment Share on other sites More sharing options...
Pittcrew Posted April 26, 2013 Author Share Posted April 26, 2013 the switch itself is broken so im now waiting till payday to get the part. thank you all for your help Link to comment Share on other sites More sharing options...
Stang70Fastback Posted April 26, 2013 Share Posted April 26, 2013 Depending on what is broken it might be an easy fix. I suggest, since the switch isn't working ANYWAY, that you remove it from the door and take it apart. I once fixed mine by flipping a small piece of plastic around that had simply worn out on one end. Link to comment Share on other sites More sharing options...
Sludgeroo Posted April 26, 2013 Share Posted April 26, 2013 Take a 12v battery and run leads to the window motor and see if its good. Being in auto glass I've done this a million times over, if it does work, your switch is bad, it barely is anything else. Just hope that you don't have to replace the window motor because the regulator and whole assy on subi's are ridiculous. Good luck, I think it may just be the switch Link to comment Share on other sites More sharing options...
Pittcrew Posted April 26, 2013 Author Share Posted April 26, 2013 thanks for the help this is my first subaru so im kinda flying blind Link to comment Share on other sites More sharing options...
twisty Posted April 30, 2013 Share Posted April 30, 2013 Take a 12v battery and run leads to the window motor and see if its good. Being in auto glass I've done this a million times over, if it does work, your switch is bad, it barely is anything else. Just hope that you don't have to replace the window motor because the regulator and whole assy on subi's are ridiculous. Good luck, I think it may just be the switch the motors canbe replaced without taking the full regulator out. ive replaced both of mine in my wagon with a bit of work. also, the motors are the exact same as the 97ish imprezas, just reversed. their passenger door motor is our driver door and vice versa. the regulators dont seem to be the same, but the motors are interchangeable. make sure you drop some lube on those gears. Link to comment Share on other sites More sharing options...
spooln30 Posted May 2, 2013 Share Posted May 2, 2013 In 15 years in the repair bizz I don't think I have ever replaced a window motor on a second gen legacy. Get a test light and check for 12v and ground at the motor. Can you work all of the other windows from the master switch? Link to comment Share on other sites More sharing options...
johnegg Posted May 2, 2013 Share Posted May 2, 2013 it is almost always the switch, drivers door. Link to comment Share on other sites More sharing options...
Pittcrew Posted May 3, 2013 Author Share Posted May 3, 2013 well the switch will be here next week guys thanks for all the help. next i have a question does anyone have an exhaust for this car that they are selling i am having no luck finding anything. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 3, 2013 Share Posted May 3, 2013 Oem? Link to comment Share on other sites More sharing options...
Sludgeroo Posted May 3, 2013 Share Posted May 3, 2013 The gears and pulleys in the way our frameless windows get super worn. It would be a shame to replace the motor and have tired mechanical bits that break easy. Its just as easy to replace that while youre in the IMO. But regardless, its usually the switch Link to comment Share on other sites More sharing options...
Pittcrew Posted May 4, 2013 Author Share Posted May 4, 2013 I got a new switch in. my drivers window works again but not i can controle passenger side with it. but im fine with that for now. but i want a better sounding exhaust. am i going to have to piece together one? Link to comment Share on other sites More sharing options...
