DuckFan Posted November 17, 2007 Share Posted November 17, 2007 Owners manual just states to have your subaru dealer do this as it may be difficult. Where the fogs sit, there is a huge piece of plastic. Do I access the bulbs from underneath in the wheel well? What do I need to remove to access the stock fog bulbs for replacement? Any help is appreciated. Jared Link to comment Share on other sites More sharing options...
DuckFan Posted November 17, 2007 Author Share Posted November 17, 2007 this is for a 2006 Outback Wagon 3.0R VDC Limted Link to comment Share on other sites More sharing options...
1-3-2-4 Posted November 17, 2007 Share Posted November 17, 2007 Ha.. sounds like the pain in the ass thing I had to do for my 03 Forester XS it said the same crap "take the car to a SUBARU dealer" Phfff.. the only reason is becuse it's a very tight space and if you have large hands then it's an issue.. also if it's anything like my forester I had to do everything by feel... I pretty much had to feel my way around the socket where the bulb sticks in. Link to comment Share on other sites More sharing options...
DuckFan Posted November 17, 2007 Author Share Posted November 17, 2007 I am not worried about that so much as just getting to the assembly is a pain in the ass. I know there are other Wagon owners with factory fog that have changed bulbs. I can wait it out. Link to comment Share on other sites More sharing options...
turboWagon Posted November 17, 2007 Share Posted November 17, 2007 I am not sure about fog light but it's pretty easy to remove the entire bumper, once you have the bumper out it’s really easy to change it. Search the thread of how to install custom grill and you will find the instruction of removing bumper. To remove the bumper, the main trick is the bolt inside of wheel well. Link to comment Share on other sites More sharing options...
Bbc84 Posted November 17, 2007 Share Posted November 17, 2007 yea the only way i figured out was to remove entire bumper. this is for a 08 LGT Link to comment Share on other sites More sharing options...
PhilT Posted November 17, 2007 Share Posted November 17, 2007 Jack the front of the car up. There's a couple of pop its holding the front of the wheel liner in place. Pull them out, you can then pull back the liner to get access to the bulbs, take 10 minutes for both Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Gire Posted November 17, 2007 Share Posted November 17, 2007 ^^^ I didn't jack the car up, but it would help a lot. OP- You can wedge yourself in there and do it out on your driveway without a lot of help. Unless you are a giant. Link to comment Share on other sites More sharing options...
outback07 Posted November 17, 2007 Share Posted November 17, 2007 Hi i have the 2007 Outback but its the sedan. I believe its the same for both its so easy. You ll need a flat screw driver. 1. You have to pop a few push locks thats what i call them they look like plastic screws take the ones that are closest to the end of the bumper out. 2. Then you can bend the plastic underguard just enough to fit your hand don't worry it wont break. Its tough plastic once you look from the bottom you ll get an idea. very easy Link to comment Share on other sites More sharing options...
PhilT Posted November 17, 2007 Share Posted November 17, 2007 ^^^ I didn't jack the car up, but it would help a lot. OP- You can wedge yourself in there and do it out on your driveway without a lot of help. Unless you are a giant. If your car is lowered, then you need to Unless you have the body of Paris Hilton Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Gire Posted November 17, 2007 Share Posted November 17, 2007 My friend does! I shoved him underneath to do the job. I stood there and drank beer! Link to comment Share on other sites More sharing options...
TSiWRX Posted November 19, 2007 Share Posted November 19, 2007 Going from above -> http://www.legacygt.com/forums/showthread.php?t=15343&highlight=fog Going from underneath ("traditional" method) -> http://www.legacygt.com/forums/showthread.php?t=9316&highlight=fog+light+bulb <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Th3Franz Posted January 7, 2009 Share Posted January 7, 2009 Installed new PIAA fogs tonight and after a drive in light snow they are much nicer than stock. I used the "top" method and slid the fog light assembly out the front. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
BrownBoy Posted January 7, 2009 Share Posted January 7, 2009 replaced a busted piaa foglight yesterday afternoon. 15 mins with jacking up the car. NO way for me to get under the car without jacking it up. Hell, I can't get the jack under the car:lol: Link to comment Share on other sites More sharing options...
iNVAR Posted January 11, 2009 Share Posted January 11, 2009 i'm a small guy (5'5") and my hands are pretty small too.. or rather they're the right size for my height. so things were pretty simple for me. it was my first time doing it too and only took me about 15 minutes in total. i didn't jack up the car. i just lay on the ground beside the front corner, near the fog. i reached in, removed a few popits, pushed the shroud/covering off to the side a bit (never took the entire thing off) reached my hand in, undid the tab securing the bulb assembly in, removed it, swapped bulbs, replaced assesmlby, and put popits back in. i really don't think anyone needs to jack up the car to replace the foglight bulbs.... just need to reach in there, that's all. i wish i still had the link to the instructions that i found here on the forums using search, but i don't have it bookmarked anymore, so you'll have to search it yourself. Link to comment Share on other sites More sharing options...
TSiWRX Posted January 11, 2009 Share Posted January 11, 2009 ^ I like "going under," too. I'm about 6-foot, even, medium build. I've been told by some orthopods and whatnot that I've got pretty big forearms for a guy my size, but I'm definitely not Popeye, either. I still like to go from underneath, although I will confess that on my slightly lowered + chin-lip'ed (DIY lip) vehicle, I found it nearly impossible to do this "by feel," even parking the car over my garage lip (to give me an additional inch or so of wiggle room). I had to jack her up. And no, this is far from my first time in that area. Here's the old description of how to go from underneath: http://www.legacygt.com/forums/showthread.php?t=9316&highlight=fog+light+bulb Here's how to go from the top, via Roundboy's Walk-Through, also now pretty dated. http://legacygt.com/forums/showthread.php?t=15343&highlight=fog <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
Cutler Posted July 12, 2010 Share Posted July 12, 2010 Very easy swap, did mine in 15m.... Link to comment Share on other sites More sharing options...
Pawlwawl06 Posted August 10, 2010 Share Posted August 10, 2010 Shouldn't there be plenty of clearance to begin with, you know, since its an Outback? I jacked up the front of my car on a slight downward slope and moved around the mud shields to get the foglights in the bumper, but I'm lowered. Link to comment Share on other sites More sharing options...
Naylor Posted September 15, 2010 Share Posted September 15, 2010 is it normal to feel like you have to "force" the plug/harness back into the assembly? i'm trying to re-connect my fogs and i feel like i'm having to force the connector in. Link to comment Share on other sites More sharing options...
bluesuby Posted September 15, 2010 Share Posted September 15, 2010 is it normal to feel like you have to "force" the plug/harness back into the assembly? i'm trying to re-connect my fogs and i feel like i'm having to force the connector in. If I'm hearing you correctly, there is difficulty putting the assembly back together. I attribute it to not enough slck on the wires. Once you connect the wire from the H3 bulb, it's tough keeping the ground wire connected. Link to comment Share on other sites More sharing options...
