Gates Timing Kit at FBP
Is this kit worth it?
You get timing belt, tensioner, all pulleys, and water pump for $275 (big sale). I need this soon, so I was thinking of picking it up.
Does anybody know if the belt in this kit is the kevlar belt? Are all gates belts kevlar? If nobody knows, I'll email FBP.
Thanks
lol
  • Replies 69
  • Created
  • Last Reply
OK. That's good to know.
So what is the proper recommended change interval for the timing belt?
30k miles if your drift
45k miles is you live your life 1/4 mile at at time
60k miles if you drive it like you stole it (in which case you are 20k miles late :eek:
95k miles if you drive the car "spiritedly"
105k miles if you drive like an old lady and don't care about your car?
You are incorrect.
No, he isn't.
The easiest proof-in-point? The owners manual. There is no "severe duty" change interval.
I could run the numbers, but it's pointless to do so. Driving at higher RPM is actually BETTER for the life of the timing belt than pussy-footing around is.
To replace your timing belt at 80k is spending money prematurely. Even the 105k interval provides significant margin of safety.
The 105k interval is, probably, more for sake of the tensioner and idlers.
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
I called my local dealer this morning to check on pricing for a timing belt change. They said it was four hours and costs $500. I asked them what it includes and they said, it ONLY includes the timing belt. No water pump, no tensioner, no drive belts, nothing else, but they will "check everything over" while they are in there. Hence, I ordered my kit today and will install it myself. Also ordered thermostat and all new coolant hoses and an AVO MAF hose. My wallet hates me now...
Why are you asking me? You clearly know everything there is to know about this car.
I'm perfectly willing to listen to any well reasoned argument stating that timing belt "wear" is independent of driving intensity, but none have been presented here. :(
lol
Actually you seem to be the one that knows since you know that I am wrong. That is why I was asking you for advice. I'd like to know why Subaru seems to think that 105k miles is an appropriate interval and to sort out when I should change my timing belt.
I suppose the answer would involve thinking about what the timing belt actually does :eek:
Why
Wait. You are operating on the premise that driving style changes the life of the timing belt, simply because you assume that it does? Not a great idea.
1) A timing belt does nothing more than... time the cams. It doesn't even do that in the AVCS and dual AVCS cars (not directly). The only torque the timing belt is exposed to is resistance from the cams and drag from the water pump and various idlers, which is shockingly little in relation to the design constraints of the belt.
2) You don't shift fast. No matter HOW fast you think you shift. You don't shift fast enough to have even the most remote impact on the timing belt. You CERTAINLY aren't accelerating fast enough to have an impact either. The timing belt is damped by the mass of the rotating assembly. You have to accelerate that mass at a rate capable of stretching the belt, and you arent. You probably put the belt under greater stress when you stall the car, than you do at WOT shifts.
3) Gear belts, and most belt drives, are most efficient around the 4000feet-per-minute range. I don't know the cut length of the timing belt, but finding the RPM at which the timing belt is going 4000fpm will tell you the engines most efficient RPM. For almost every car I HAVE done that for, I've found that the most efficient RPM is typically between 2800 and 3600 rpm. That's prime highway cruise speed. Pussy footing around town is going to force the timing belt to operate outside of it's peak efficiency range, and therefore shorten its life.
Why
because at higher belt speeds air get "trapped" between the cogs on gear & teeth on belt creating a cushion , at low belt speeds the air can escape faster = less cushion .
some facts ;
rapid changes in speed/load wear both belt & sprocket faster , ie; stickshift car shifted quickly/hard would be expected to wear faster than auto car .
stiffer valve springs or higher volume water pump on a subie will wear a belt faster
constantly changing , up down in belt speed will wear quicker than one that cruises at 3500 rpm forever , highway car vs city car
My thoughts exactly. I didn't even consider it until, but underhood temperatures will also be much higher when you're driving the car like you stole it.
I suppose some of you also believe that the belt lasts longer at elevated temperatures as well? :spin:
lol
