scosocROKKER88 Posted April 13, 2013 Share Posted April 13, 2013 Driving home yesterday, 70mph, cruise on, cold and rainy, 122, xxx miles. Cruise shuts off, cc light blinking cel on Read the code p0170 "lean bank #1" Searched forums and google nothing related to 2006 lgt 5mt to be seen. I installed perrin short ram last weekend and cleaned maf and checked connector, seems fine. Don't know when plugs were done last or if/when O2 sensors were ever replaced. All info is welcomed. Thank you Link to comment Share on other sites More sharing options...
ScoobyDoo94 Posted April 13, 2013 Share Posted April 13, 2013 I think that might mean cylinder 1 is running lean. Replace the spark plugs and see what happens. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 13, 2013 Share Posted April 13, 2013 http://www.obd-codes.com/p0170 While reading your post, I was thinking front O2 sensor. After reading the above link, I still think front O2 if your MAF is ok. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
subiestang Posted April 13, 2013 Share Posted April 13, 2013 did you tune for the intake? Link to comment Share on other sites More sharing options...
StormLGT Posted April 13, 2013 Share Posted April 13, 2013 Change the TGV's and manifold gaskets. Fixed mine when it came up. Link to comment Share on other sites More sharing options...
Serb Legacy GT Posted April 13, 2013 Share Posted April 13, 2013 I just finished dealing with this. I had new spark plugs so I knew it wasn't it. I swapped coils, still same problem. I replaced the o2 sensor and still had a lean bank 1. I replaced the injectors and fuel pump, good as new! Now each car could be different, I had an accessport and was able to check cylinder roughness and it would hit #1. I had a slight shake at idle, and again at around 2k rpm and it was verified with a roughness count in cylinder 1. Now the car is smooth as new. At 122k, when was the last time you replaced your plugs? If it's been at least 30k miles, it might not be a bad thing to do and could fix it. If not, o2 sensor may fix it. After that, it could be injectors (I did the pump as well at that point). Just my experience, sadly there's no way to check for sure without replacing some parts. Link to comment Share on other sites More sharing options...
scosocROKKER88 Posted April 13, 2013 Author Share Posted April 13, 2013 did you tune for the intake? Perrin advertises it as no tune necessary. Cbe coming soon was going to tune then. I bought the car 3 weeks ago and haven't done a thing except oil change and install intake. Going to check if the clamps are still tight to make sure there isn't un metered air flowing into intake as well. Link to comment Share on other sites More sharing options...
scosocROKKER88 Posted April 13, 2013 Author Share Posted April 13, 2013 I just finished dealing with this. I had new spark plugs so I knew it wasn't it. I swapped coils, still same problem. I replaced the o2 sensor and still had a lean bank 1. I replaced the injectors and fuel pump, good as new! Now each car could be different, I had an accessport and was able to check cylinder roughness and it would hit #1. I had a slight shake at idle, and again at around 2k rpm and it was verified with a roughness count in cylinder 1. Now the car is smooth as new. At 122k, when was the last time you replaced your plugs? If it's been at least 30k miles, it might not be a bad thing to do and could fix it. If not, o2 sensor may fix it. After that, it could be injectors (I did the pump as well at that point). Just my experience, sadly there's no way to check for sure without replacing some parts. Yeah I don't want to just throw parts at it and hope that's the cause/fix. That being said new plugs are cheap and good to have anyway. Link to comment Share on other sites More sharing options...
scosocROKKER88 Posted April 14, 2013 Author Share Posted April 14, 2013 Update: replaced clamps on intake and made sure everything is good and snug replaced spark plugs (1step colder, triple checked the gap) oil change cleared code. 200miles since all that code hasnt returned. Fixed it? I hope Link to comment Share on other sites More sharing options...
