jbangoy Posted May 24, 2013 Share Posted May 24, 2013 I went down to try and replace my spring bolts that had snapped when installing my shorty, and I have a slight leak where the donut gasket fell apart a little bit. I tried to pry off the old one with no luck just made the leak a little worse anyone have any tips how to take the old one off so I can put on this new one I got? Link to comment Share on other sites More sharing options...
baconbits Posted May 24, 2013 Share Posted May 24, 2013 If the old one is toast and you have a new one, why care if you destroy the old one it getting it off? Pry that bish off there... Link to comment Share on other sites More sharing options...
Dbl_D718 Posted May 24, 2013 Share Posted May 24, 2013 Mine was so rusted/stuck on there that I couldn't pry it off. I had to use a Dremel tool with a little cut-off wheel to cut the gasket apart to get it off. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
