iahtnoob Posted May 5, 2010 Share Posted May 5, 2010 Just replaced rotors and pads. Is the metal bracket on the brake pad which is circled in yellow suppose to be in this position or is it suppose to bend under the brake pad end and out of sight? http://i294.photobucket.com/albums/mm92/iahtnoob/SL734414color.jpg Link to comment Share on other sites More sharing options...
subawang Posted May 5, 2010 Share Posted May 5, 2010 Incorrect. That is the low pad indicator. It should be positioned next to the pad. You can either bend it back to the original position or just cut it off. Link to comment Share on other sites More sharing options...
GTTuner Posted May 5, 2010 Share Posted May 5, 2010 That is the correct position. It is not a wear indicator, it is a return spring. Link to comment Share on other sites More sharing options...
GTTuner Posted May 5, 2010 Share Posted May 5, 2010 Here you go. Link to comment Share on other sites More sharing options...
iahtnoob Posted May 5, 2010 Author Share Posted May 5, 2010 thanks gttuner and thanks subawang for letting me know to never listen to your advice. Link to comment Share on other sites More sharing options...
papa g Posted May 5, 2010 Share Posted May 5, 2010 lol! BE committed to DO what it takes to HAVE more of what you want in your life!!! Link to comment Share on other sites More sharing options...
GTTuner Posted May 5, 2010 Share Posted May 5, 2010 No prob. Don't go too hard on subawang, it's easy to mistake that for not belonging there. The first set of pads I did on my car those clips had me scratching my head for a few minutes until I noticed the wear indicator on the inside pad. Link to comment Share on other sites More sharing options...
ebpda9 Posted May 6, 2010 Share Posted May 6, 2010 never knew that. maybe that is why i go thru so many brakes Link to comment Share on other sites More sharing options...
subawang Posted May 6, 2010 Share Posted May 6, 2010 My bad, I wasn't paying careful attention. With all the brake changes I do, I should've caught that. On a related note, I wouldn't take my advice anyways. Link to comment Share on other sites More sharing options...
GTTuner Posted May 6, 2010 Share Posted May 6, 2010 My bad, I wasn't paying careful attention. With all the brake changes I do, I should've caught that. On a related note, I wouldn't take my advice anyways. I've given my share of shaky advice in my days. Link to comment Share on other sites More sharing options...
