BoostWagon Posted November 5, 2012 Share Posted November 5, 2012 So I've had oil dripping off the bottom of my filter through multiple oil changes, just recently had the O-ring at the top of the cooler replaced. That didn't solve the problem. Filter seems tight enough. Doesn't look like the sides of the oil cooler body above the filter have any oil on them, nor does the short line that comes down and 90's with a short hose into the inlet or discharge of the cooler (that would be coolant anyway, I assume). I do see signs of oil at the joint of the cooler base and the inlet or discharge coolant tubes, where they meet the base of the cooler. Does it make sense that oil would be leaking here if the joint were fatigued? I'm using about a quart every 750 miles or so, some may be burnt (115K miles), the rest certainly leaked. I know I need to fix it eventually, but in the short run is there a risk of catostrophic failure where something lets go and I dump all my oil on the road? I'd like to at least get a few thousand miles on my 2 week old Mobil 1 EP oil change. If I do have to replace the cooler, it looks like you drain the coolant, disconnect and replace the short elbow hoses, short coolant pipe (rusted), and clips as needed. It also looks like the same pipe that the oil filter threads onto also threads into the block, and holds the cooler in place. Are this pipe and the cooler difficult to remove? This seems like a pretty straightforward job, but I'm a relative novice who has a healthy respect for the unanticipated, and I work pretty slowly. Any tips would be appreciated. Link to comment Share on other sites More sharing options...
BoostWagon Posted November 10, 2012 Author Share Posted November 10, 2012 bump - any thoughts? Link to comment Share on other sites More sharing options...
BigBad Posted November 10, 2012 Share Posted November 10, 2012 Here's a helpful link on changing out the oil cooler gasket. http://www.subaruoutback.org/forums/99-do-yourself-illustrated-guides/36964-diy-how-replace-oil-cooler-gasket-oil-filter-leak.html I've never had to change one out myself as I haven't had the problem yet. The other area you could check is the oil pump gasket for leaks. If you already paid to have the cooler gasket replaced then i would bring it back to them. Link to comment Share on other sites More sharing options...
BoostWagon Posted November 17, 2012 Author Share Posted November 17, 2012 Ended up replacing the whole cooler. Had Dent Sport Garage replace the clutch yesterday, figured I'd have them do the cooler at the same time and save myself the aggravation. We ruled out everything else that seemed logical, ended up deciding the cooler must be at fault. No oil leaks evident this am after 50 miles of driving, appears to be fixed. They were able to re-use the Mobil 1 EP that I'd JUST changed, at least, so that helped ease my pain a bit. I get stuff like clutches, brakes, fuel system stuff, and even turbos needing replacement, but its c&*%$ like this that really annoys me. Its a simple heat exchanger, shouldn't leak after 7 years, especially when its a $215 part with no moving parts. Perhaps I'm unrealistic..... Link to comment Share on other sites More sharing options...
Max Capacity Posted November 17, 2012 Share Posted November 17, 2012 Hard to say but, may be when they repalces the o-ring they didn't install it right or something happened. I don't recall the oil cooler itself leaking and anyones car. But it seems your all set now. Next time may be put your post in the 4th gen forum. You may get more hit's on it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
2furious Posted December 10, 2012 Share Posted December 10, 2012 It sounds like mine has the same issue. I found oil came from the filter and I changed my oil last Saturday and there was quite an amount of oil on the garage floor. I made sure I tightened it up pretty good when I put the filter on. I will check the leaking tonight if the oil is coming from the filter. Then, it probably from the o-ring. From Desert to Rocky to SLC !!! Link to comment Share on other sites More sharing options...
spec chode Posted March 15, 2015 Share Posted March 15, 2015 Ended up replacing the whole cooler. Had Dent Sport Garage replace the clutch yesterday, figured I'd have them do the cooler at the same time and save myself the aggravation. We ruled out everything else that seemed logical, ended up deciding the cooler must be at fault. No oil leaks evident this am after 50 miles of driving, appears to be fixed. They were able to re-use the Mobil 1 EP that I'd JUST changed, at least, so that helped ease my pain a bit. I get stuff like clutches, brakes, fuel system stuff, and even turbos needing replacement, but its c&*%$ like this that really annoys me. Its a simple heat exchanger, shouldn't leak after 7 years, especially when its a $215 part with no moving parts. Perhaps I'm unrealistic..... Did this fix the leak? Link to comment Share on other sites More sharing options...
BoostWagon Posted March 16, 2015 Author Share Posted March 16, 2015 It did. Sold the car more than a year ago, so this repair is probably 2 years old at this point. Leak was where the tube enters the cylinder of the cooler. Not hard to replace if the car is on a lift, PITA if not. Link to comment Share on other sites More sharing options...
StarterGang Posted March 24, 2016 Share Posted March 24, 2016 Having this problem right now.. Thank god for this thread Link to comment Share on other sites More sharing options...
jsmythe Posted August 1, 2016 Share Posted August 1, 2016 i just did this and there's a lot of dirt and grit that can work its way into the receiving surface for the oil cooler. i also suspect that mechs way over tighten the filters in an attempt to stop the leaking. when i finally got everything down there was dirt that prevented a good seal on the o-ring. tip - take out the heat shield that gets in the way of the coolant pipes. i finally took off the four screws holding it in place and did in 10 minutes what took me the better part of an hour or more of maneuvering to get the hoses off. Link to comment Share on other sites More sharing options...
