xilles Posted November 9, 2012 Share Posted November 9, 2012 Hi legacy gt. I'm having a no start problem with my 07 lgt auto.Lets start with the story first. Changed my oil. Installed my air box for winter. Took my battery out to place plastic tray in./warmer Go to start car. "Run system check change" error on.no start Turn key everything powers up and radio dies out slowly Blinking if I change to sport or sport sharp same corresponding blinking Things checked. Battery. Grounds. Wiring harness. Tried using auto start nothing Things performed. Cleaned terminals on battery Replaced power to battery connector Cleaned maf and other assorted connectors on wiring harness Connected laptop and tried to read from ecuflash. No tables pulled up. Could not connect to ecu. All fuses in main box and sub box checked and good. My diagnosis. Bricked ecu. Can anyone give me more insight about these legacys. It looks like I'm going to be building a unbrick module now with help from my electrical engineering friends. Cheers Link to comment Share on other sites More sharing options...
cryo Posted November 9, 2012 Share Posted November 9, 2012 I know its a long shot but check the big connector by the pass side right behind the abs module. It is a spring clip and if bumped it can pop undone and can cause this. No guarantees but its woth a shot to check. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
ripemeat Posted November 9, 2012 Share Posted November 9, 2012 if the radio slowly dies out, it's not the ecu. still sounds like a battery issue. Link to comment Share on other sites More sharing options...
xilles Posted November 9, 2012 Author Share Posted November 9, 2012 Battery was swapped out with 3 different known good. Also we're loaded tested and fully charged. I understand what you mean by the radio slowly dying. i can turn the key and nothing happens no fuel pump no relays going off. I will check this spring clip behind the abs module as I did man handle the air box back into the car. I already have on order parts needed for unbricking like a boss. I will try to get my engineering friends to make up a couple boards just in case. Link to comment Share on other sites More sharing options...
xilles Posted November 9, 2012 Author Share Posted November 9, 2012 If this is the spring connector your referring too. It's the main engine body engine harness and I just unhooked and replaced back.. The video is after I did all the check and reseated the main engine harness connector http://i150.photobucket.com/albums/s117/glenpickrodt/5D35CEF9-B174-48BC-BC69-D86C1B4D0D5B-750-00000058320D2E9C.jpg Link to comment Share on other sites More sharing options...
xilles Posted November 10, 2012 Author Share Posted November 10, 2012 So after getting off the phone with tactrix we could not confirm the ecu was bricked but we did confirm the car was not going into test mode with green connectors plugged in. Any insight?? Going to recheck everything in the morning. Hopefully I just knocked something loose under the car. Damn nor'easter and sandy. No power and doing everything from my phone sucks. Link to comment Share on other sites More sharing options...
2manysubies Posted November 14, 2012 Share Posted November 14, 2012 Interesting, Sorry I have no help for you. Subscribed. R/Mac Link to comment Share on other sites More sharing options...
xilles Posted November 19, 2012 Author Share Posted November 19, 2012 so i just got back my ecm from tactrix. ecm was reprogrammed wiring for cam sensor soldered and heat-shrinked and wrapped up properly still "run system change check mode" can not connect to ecm. going to go through and check the biu and etc components. maybe my key lost program somehow but will check everything in the morning. any ideas!!!! Link to comment Share on other sites More sharing options...
BAC5.2 Posted November 19, 2012 Share Posted November 19, 2012 Do any of the electrical systems still work if you put the key in the ON position? I assume you checked the ECU fuse, right? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Alopez6337 Posted November 23, 2012 Share Posted November 23, 2012 Any update on this?? I ran into the same issue with my 07 specB after I did an engine swap with some mods. I already tried another battery. My radio doesnt die. But it does cut out everytime I turn the key to the START position and cut back on in the ON position. Any Ideas?? I have a stock ecu if that helps. Link to comment Share on other sites More sharing options...
Windy Road Posted November 24, 2012 Share Posted November 24, 2012 Ecu is bricked.... http://legacygt.com/forums/showthread.php/run-mode-system-check-error-186829.html?t=186829 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
xilles Posted November 27, 2012 Author Share Posted November 27, 2012 ecm is not bricked. ran a few tests looks like my ignition is cutting out when switched to on. cant connect to ecm after getting it back from tactrix. modules that work with this system are the tcm vds/vdc and biu. im going to pinout for the biu so see if theres a short somewhere in the system. also possible loss of key programming unknown status on have one key. Link to comment Share on other sites More sharing options...
xilles Posted November 27, 2012 Author Share Posted November 27, 2012 Do any of the electrical systems still work if you put the key in the ON position? I assume you checked the ECU fuse, right? what do you mean by ecu fuse Link to comment Share on other sites More sharing options...
Alopez6337 Posted November 27, 2012 Share Posted November 27, 2012 Alright I had the same issue and it turns out I left an important ground loose on the engine harness, hooked it up and it turned right over. Just a thought since that was my solution. CHECK YOUR ENGINE GROUNDS! Link to comment Share on other sites More sharing options...
cryo Posted December 28, 2012 Share Posted December 28, 2012 did you get this figured out? Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
