xmasbaby63 Posted April 15, 2013 Share Posted April 15, 2013 Have a question on an 05 Legacy. Front end had a vibration/hum, only when turning to the right. Figured it was the front left bearing, and replaced it fairly easily. At 185k, it likely needed it anyway. Right fron was replaced about 1½ years ago when some guy ran a stop sign and boradsided my wheel; no noise when turning left. Rear left was replaced; rear right will likely be replaced fairly soon. Put everything back together, along with new rotors and brakes all around and the hum/vibration seems to still be there, a little different sounding it seems. Would a bad c/v joint cause the vibration? Aside from a defective bearing being just put in, what else might I check for? Thanks... Link to comment Share on other sites More sharing options...
Max Capacity Posted April 15, 2013 Share Posted April 15, 2013 Yes a CV joint can cause that. You may want to verify the right front tire doesn't have a belt issue first. CV joints normally make a clicking sound while turning. Get under the car with a good light and check out the boot on the CV, inner and outter. I got my left front axle from Advance Auto Parts over 2 years ago for $80.00, it was 100% new not a re-man. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Scubaru03 Posted April 15, 2013 Share Posted April 15, 2013 Its possible for axle to make humming sounds but normally makes clicking noise during turns while accelerating. Also will clicked really loud under heavy load. I would check your tire could be out of balance or damaged. I would rotate the tires and see if the noise moves. Link to comment Share on other sites More sharing options...
