zanzabar Posted March 28, 2014 Share Posted March 28, 2014 i am doing a vf52 swap in a month and there are 2 shops close to me that i am trying to pick between. would you guys go yimi or gst? gst is closer and has a good reputation, but only do AP pro tunes. yimi is a bit newer and does open source, but does not have the same reputation that mike and gst have. i am a bit torn since i could drop it off and get it back done from GST, they would get most parts for me and cover their work. while yimi i would most likely go to my mechanic run it easy with spring boost and then sit around and wait for a tune and risk not having a tune for a bit. Link to comment Share on other sites More sharing options...
Drift Motion Posted March 28, 2014 Share Posted March 28, 2014 yimi moved to norcal? Link to comment Share on other sites More sharing options...
zanzabar Posted March 28, 2014 Author Share Posted March 28, 2014 I thought it was in Santa Clara but I should double check. Yah they moved I guess 26524 Ruether Ave #510, Santa Clarita, CA, United States Link to comment Share on other sites More sharing options...
OGHK87Jay Posted March 31, 2014 Share Posted March 31, 2014 Just curious how much are they charging for the AP tune? Link to comment Share on other sites More sharing options...
Heedz Posted April 1, 2014 Share Posted April 1, 2014 Go to Snail Performance in Rocklin @ FW Motorsports way worth the drive up there. Link to comment Share on other sites More sharing options...
zanzabar Posted April 1, 2014 Author Share Posted April 1, 2014 Just curious how much are they charging for the AP tune? both are $450 for a dyno tune on a fresh vf52 swap. Go to Snail Performance in Rocklin @ FW Motorsports way worth the drive up there. i am doing a vf52 swap and have no feasible way to get that far out, then back, and then back out again. Link to comment Share on other sites More sharing options...
Heedz Posted April 2, 2014 Share Posted April 2, 2014 Why can't FW install your turbo then. Link to comment Share on other sites More sharing options...
zanzabar Posted April 2, 2014 Author Share Posted April 2, 2014 Why can't FW install your turbo then. it is just too far away. GST seems very popular and they have been helpful in making sure i was going to get what i wanted out of the car. they are also about 20min away so if anything happens i can get it towed or make a quick run down there. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted April 3, 2014 Share Posted April 3, 2014 I'll second the recommendation to use Snail in Rocklin at FW. I'd email Travis and ask him to send a base map for your drive up to have a full dyno tune. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
LGTfoLIFE Posted May 24, 2014 Share Posted May 24, 2014 Why can't FW install your turbo then. How much do they charge to install a turbo & tune? Link to comment Share on other sites More sharing options...
510Finn Posted May 24, 2014 Share Posted May 24, 2014 How much do they charge to install a turbo & tune? Best to call or email them for a quote, plus you can answer the relevant questions that will happen unless you email them all the details about your build. (did you change the fuel pump, injectors, etc.) 08 Spec B details Link to comment Share on other sites More sharing options...
LGTfoLIFE Posted May 24, 2014 Share Posted May 24, 2014 Best to call or email them for a quote, plus you can answer the relevant questions that will happen unless you email them all the details about your build. (did you change the fuel pump, injectors, etc.) I haven't changed them yet. I was planning on installing them the same time the turbo goes in or maybe before Link to comment Share on other sites More sharing options...
Chris GTO TT Posted June 23, 2014 Share Posted June 23, 2014 I realize this thread is a little old now but just for reference this is the high boost stage 2 tune Travis did on my spec.B https://www.dropbox.com/s/b1eeogkl77bt64f/Chris%20Craig%20LGT%20Spec%20B%20S2.pdf 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
