1-3-2-4 Posted April 29, 2017 Share Posted April 29, 2017 I've always wondered what this part is Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
WahooNo2 Posted April 29, 2017 Share Posted April 29, 2017 looks like a pcv or breather hose, where did it come from? Link to comment Share on other sites More sharing options...
relative4 Posted April 29, 2017 Share Posted April 29, 2017 The end you're holding is normally mounted in the stock turbo inlet. The hose you're holding is not normal, somebody cut the connector out of the inlet, obviously tearing it up pretty well in the process, and attached the hose to it. The farcical "PCV leak detector" electrical connector attaches to the side shown in the second photo; the PCV hose inserts into the hole shown in the first photo and is held in place by the electrical connector. I'm guessing you have an aftermarket inlet, and whoever installed it didn't know you can defeat the "leak detector" by pulling the jumper out of the PCV hose connector and sticking it into the harness connector. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 29, 2017 Author Share Posted April 29, 2017 The end you're holding is normally mounted in the stock turbo inlet. The hose you're holding is not normal, somebody cut the connector out of the inlet, obviously tearing it up pretty well in the process, and attached the hose to it. The farcical "PCV leak detector" electrical connector attaches to the side shown in the second photo; the PCV hose inserts into the hole shown in the first photo and is held in place by the electrical connector. I'm guessing you have an aftermarket inlet, and whoever installed it didn't know you can defeat the "leak detector" by pulling the jumper out of the PCV hose connector and sticking it into the harness connector. Oh I think it's coming back to me now I think this was the one that was sideways under the intake manifold I'm hoping when all is done I can make it not look so much like a huge mess. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
relative4 Posted April 29, 2017 Share Posted April 29, 2017 It was on top of the inlet and pointed toward the driver side. Depending on what inlet you're using, you have a variety of options for eliminating that mess. Link to comment Share on other sites More sharing options...
JmP6889928 Posted April 29, 2017 Share Posted April 29, 2017 It's a mmunson volpulizer designed to assist the festerus dihydroscopic valve Link to comment Share on other sites More sharing options...
relative4 Posted April 29, 2017 Share Posted April 29, 2017 It's a mmunson volpulizer designed to assist the festerus dihydroscopic valve Jane, you ignorant slut. Don't listen to him, it's the flux capacitor. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 29, 2017 Author Share Posted April 29, 2017 It was on top of the inlet and pointed toward the driver side. Depending on what inlet you're using, you have a variety of options for eliminating that mess. The car has a avo inlet but I'm going to change it to something else Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
LatentWagen Posted April 29, 2017 Share Posted April 29, 2017 Jane, you ignorant slut. Don't listen to him, it's the flux capacitor. Looks like a plumbus to me. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
relative4 Posted April 29, 2017 Share Posted April 29, 2017 Well, I'm finding the Perrin inlet is crap for the '05. It's 3/4" too long and hits the PS pump. I'm returning it and sticking with stock. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted April 29, 2017 Author Share Posted April 29, 2017 Thats the first I've heard of that Link to comment Share on other sites More sharing options...
LatentWagen Posted April 30, 2017 Share Posted April 30, 2017 Better too long than too short. You could always trim it down a bit to fit... LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
