03silvertiger Posted April 28, 2011 Share Posted April 28, 2011 I been wanting a subwoofer in the car just to fill the bottom end of music with something. I found a 8" kicker sub that I was gunna put back there just wondering if anyone has dont it before. And what your opinions are on it. Link to comment Share on other sites More sharing options...
Rene2.5RS Posted April 28, 2011 Share Posted April 28, 2011 I have just been looking into doing the same. H&K system is ok but deff could benefit from a better low end driver in the deck Link to comment Share on other sites More sharing options...
03silvertiger Posted April 28, 2011 Author Share Posted April 28, 2011 I just put all new Polk audio speakers and need the lower end. so that the speakers dont get distorted playing all the frequencies it was poor choice to go with two way speakers. But they sound good I just will limit the frequncies they play when i add the sub. I m thinking of the kicker 10c84. Link to comment Share on other sites More sharing options...
kb2spn Posted May 3, 2011 Share Posted May 3, 2011 I been wanting a subwoofer in the car just to fill the bottom end of music with something. I found a 8" kicker sub that I was gunna put back there just wondering if anyone has dont it before. And what your opinions are on it. Make sure the sub is made for free air or you will have to build a box around it. Link to comment Share on other sites More sharing options...
garbo41610 Posted May 3, 2011 Share Posted May 3, 2011 Look for subs with a Qts of around 0.6 to 0.8 and something with a high efficiency. If the OEM amplifier is being used then the driver will need to make the most out of the small amount of power it's being fed. Link to comment Share on other sites More sharing options...
Collins Posted May 3, 2011 Share Posted May 3, 2011 Just a warning.. I wanted to this a while back.. I got so many people tell me not to put it on the back shelf.. Apparently it just shakes the car to bits.. More rattles than bass. I went with a 12" kicker sub in a box (on sale.. $130 Aus $) with a kicker mono amp and I can get it to 130 db without rattling. Kicker make great stuff Link to comment Share on other sites More sharing options...
underground000 Posted May 3, 2011 Share Posted May 3, 2011 Letting OP know the only open air sub Kicker makes in the Comp, Comp only not CompVR/CompVT... 5eat downshift rev match:) Powder coated wheels: completed:) Link to comment Share on other sites More sharing options...
03silvertiger Posted May 3, 2011 Author Share Posted May 3, 2011 do you guys recommend any other subs? Like I said I most likley wont keep it loud but I just want to get low end in my car i m not big about shaking things just want to get some bass. Link to comment Share on other sites More sharing options...
garbo41610 Posted May 3, 2011 Share Posted May 3, 2011 If the subs is mounted correctly on the parcel shelf then you won't have any issues with rattles. Vibe make a pretty decent 8" sub that can be used with pretty good results in free air applications. Better than a Kicker or other such entry level sub. Link to comment Share on other sites More sharing options...
KUSoob Posted May 3, 2011 Share Posted May 3, 2011 I have a spare tire mounted box, I'm working on posting an install thread. It's by far the best option for maximum bass/trunk space. Link to comment Share on other sites More sharing options...
soloz2 Posted May 4, 2011 Share Posted May 4, 2011 If you want to mount a sub in the rear deck you're going to have to dampen it quite a bit. Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
03silvertiger Posted May 4, 2011 Author Share Posted May 4, 2011 do you have a link for this vide sub. I was thinking of a spare tire box too but i figured this is easier. Link to comment Share on other sites More sharing options...
bomberlegacy Posted May 5, 2011 Share Posted May 5, 2011 DLS makes a good free air 8. oa8 is the model I believe. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
peteyjr Posted May 6, 2011 Share Posted May 6, 2011 Years ago when Subs weren't as advanced, I had three 8" Free air Kicker subs (made specifically for open air ) It sounded great at low end in the3 15-30 htz region but lacked a bit of dampening and control. Have gone to boxes since and never looked back Link to comment Share on other sites More sharing options...
markc0220k Posted May 9, 2011 Share Posted May 9, 2011 I been wanting a subwoofer in the car just to fill the bottom end of music with something. I found a 8" kicker sub that I was gunna put back there just wondering if anyone has dont it before. And what your opinions are on it. you mean that 8' shallowmount (cvt8?)? if so, i can tell you that it wont fit! the diameter of the 8" kickers is about 1/4~1/6" shorter than the diameter of that heavy stock metal plate (the ring that holds the stock sub). withouth the plate, the sub is small enough to pass thru the stock hole! Link to comment Share on other sites More sharing options...
markc0220k Posted May 9, 2011 Share Posted May 9, 2011 do you guys recommend any other subs? Like I said I most likley wont keep it loud but I just want to get low end in my car i m not big about shaking things just want to get some bass. i replaced my stock sub with earthquake sws8 4ohms, just because i just want a little bit touch up on low end, and it can really give me what exactly i want!! Link to comment Share on other sites More sharing options...
