Motorola T605 Bluetooth install
mars_volta
I received my Motorola T605 Bluetooth kit from ebay today. $9.99 + 6 shipping. I mainly bought it for the stereo bluetooth so I can stream from my droid eris.
I hooked it up to the garage stereo and I'm impressed so far. I will install it in the car this week and will update.
Here is a couple pics for now.
http://www.sixthsphere.com/storage2/images/6dm1qtnv4poj1eoi91gz.jpg
http://www.sixthsphere.com/storage2/images/6o9sderiz8xibl61raa0.jpg
Minus the Bear - Drilling was playing while I took these pics with my droid eris.
http://www.sixthsphere.com/storage2/images/imcnrv026c8rozvxefv.jpg
  • Replies 54
  • Created
  • Last Reply
How does it sound? I have one sitting in a box waiting for install (I'm putting it in with my '08 radio and line-out mod). Also, if you click "play" on the Droid right after you power the t605 up, will it start playing through the speakers or do you have to switch to audio mode?
I have to play with it more. I didn't hook up the speaker or mic. I compared it with the straight out from my phone and the t605 was a bit louder. Quality seemed decent. I know I'm losing something using bluetooth, but its so nice without wires. I'm on my second S9 headphones and could not go back.
I am noticing some artifacts with bass and phasing. Not sure if its the radio and all its messing with my music, my phone or the mp3s encoding...Not terrible but I have a sharp ear and I at least noticed. I haven't noticed this with playing mp3 from cds. I wired my aux in with the FM signal. Could there be some compression, limiting or ?? going on in that path?
Is this through the "aux in" on the motorola, bluetooth, or both?
Bluetooth is compressed, but it's unknown what type of compression the phone and T605 will connect up with. It includes mandatory support for the low complexity SBC codec, and could optionally support: MPEG-1 , MPEG-2, MPEG-4, AAC, or ATRAC (thank you Wikipedia). Presuming Motorola cheeped out and went with the lowest common denominator (SBC), your music will be transcoded into essentially MPEG-1 Layer II (mp2) between 128kbs and 384kbs (depending on what the devices decide).
On possible fix though: You may be over driving the digital audio path. Start music playing on your phone and lower the bluetooth media volume.
Had a revelation this morning...
The 605 has a 1/8" aux in. The bluetooth takes precedence over the line in BUT thats perfect. I can feed the FM signal from the radio into it, and then when I want my music, the bluetooth takes over. Perfect!! No more hard switch! Be back with results..
Finally got it installed. Works good with my Droid Eris. Sound Quality is good but not perfect. I can hear some transcoding artifacts, and there is some kind of normalization or compression going on. I have to give a good week long road test. In the garage I can hear every little problem.
It is very convenient with no wires and it pairs up when I turn on the key.
There is a USB socket on it so I wonder if any hacking is possible...
The 2005-2009 radios have the ability to mute (there is a pin on the i88 conector?), the 2005 and 2006 have a phone audio input that one can use with the T605 to hear the call through the front speakers. The motorla bluetooth kits are the ones that probably work the best with the OEM phone input, the parot kits don't have the correct outputs.
Today I am a happy camper!! I was listening and was unhappy with the stereo bluetooth artifacts. I discovered that I can plug in my straight line in from the phone but still have bluetooth AVRCP media remote control while its locked and in the cubby! That was my main goal this whole time was to avoid messing with the phone while I'm driving. Sounds great!
http://www.sixthsphere.com/storage2/images/ztuq8u4ek6vzx2kxgfc3.jpg
Kind of. I just hacked the FM signal traces. I brought the FM and new line in out to a DPDT switch and fed the other side from the t605. Zero noise. I saw no need to use an internal relay and all that. Use the proper wire and it should be fine. Here is the original thread.
http://legacygt.com/forums/showthread.php/my-2005-legacy-ipod-input-21047.html?t=21047
Couple new pics:
Installed my FM/Aux switch and a power switch for the Bluetooth. In case I need to reset it, I don't need to shut off the car. Anybody have an extra ashtray assembly?
http://www.sixthsphere.com/storage2/images/ipotodzy6hgx4rgr6je.jpg
http://www.sixthsphere.com/storage2/images/wwe8ir6qxwdl8lzpc64.jpg
hopefully you didnt pay more than $15. Its a nice unit, but the stereo bluetooth stream quality is lacking. There is some research being done to find a better setup. ;)
The setup I probably would have upgraded to (if I hadn't found a Spec B radio with aux input) is the Parrot MKi9000/9100. With the quick connect harness, it should be plug and play, and plays music through the Parrot box via bluetooth, Ipod adpater, USB or 3.5 mm aux jack. A company from Israel is selling refurbs on ebay for close to $100 shipped. Sounds like a really good aux-in/Ipod alternative for people with the 05-06 non-aux head units.
I've never had a great experience with A2DP, so I wasn't planning on using the music portion. I'm more interested in doing away with my headset and having a decent hardwired speakerphone
  • 2 weeks later...
