djfrostsf Posted February 6, 2012 Share Posted February 6, 2012 Hey folks, Here is my issue, which to tell you the truth is driving me completely insane. Whenever my car is in gear you can still move the shifter left and right like butter. I like a positive feel when I'm driving. I just replaced Both of the shifter bushings. The front with a polyurethane bushing made by Energy Suspension and the rear is the Subaru STI shifter bushing. I have a Kartboy STS as well. Can someone please tell me what to replace. Or a remedy on how to fix it? Thanks, -T Link to comment Share on other sites More sharing options...
Max Capacity Posted February 6, 2012 Share Posted February 6, 2012 Get under your car with a couple of 12mm wrenches. Look up at the shift linkage. You'll see the bolt that has back out. put it back in. hopefully the nut will be there on top of the linkage, mine was. tighten it and the others real good. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
