Fijiphil Posted March 19, 2012 Share Posted March 19, 2012 Hey guys, Im gonna be replacing the valve cover gaskets this weekend in my 05 LGT as they leak just a little bit, and will be going stage 2 as well. My question is, what brand(s) of valve cover gaskets should I get? Ive had really good luck with fel-pro gaskets on other cars, but I dont know if I should be worried about getting an OEM subaru gasket or not. Also, from what I understand I will be pulling one of the exhaust manifolds when I replace my uppipe for stage 2. Again, any particular brand of gasket to get or aviod, and do i need to be worried about resurfacing the manifold before I re-install it? My prior experience with cars has been that often the manifold must be resurfaced. But I dont know if thats the case with these cars. Finally, i will be replacing spark plugs as well, just cause Ill be down in that general area anyways. Is there any real benefit from going to a 1 step colder plug on a basic stage 2 setup (uppipe, full exhaust, AP). With the exception of an intake or open-panel air filter, I have zero intentions or plans to modify the engine otherwise for the forseeable future. Im sure that this stuff may have been asked before, but I searched for a few days with no avail Any advice is appreciated!! Thanks! Phil Link to comment Share on other sites More sharing options...
iNVAR Posted March 20, 2012 Share Posted March 20, 2012 I just went with whatever FBP sent me, probably OEM. And then I used RTV. the other gaskets, I don't remember... The OEM gaskets seem pretty nice though. Are you replacing your UP? I hope you are. Make sure you seat the UP really well, or get a super thick GS gasket. It leaks sometimes at the UP->Header connection, so GS has a 12X thick one. Link to comment Share on other sites More sharing options...
Mickeytl Posted April 30, 2012 Share Posted April 30, 2012 I heard that oem and felpro are the best or most popular brand. I have used the felpro on my acura legend and never had a problem. Link to comment Share on other sites More sharing options...
SSpeed Posted April 30, 2012 Share Posted April 30, 2012 The OEM gaskets are probably better than any other thing you can get out there.. Grimmspeed makes good exhaust gaskets. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 1, 2012 Share Posted May 1, 2012 In post #37 you can see what your going to find with the valve cover. http://legacygt.com/forums/showthread.php/got-some-new-stuff-engine-r-r-184106p2.html When I pulled my Invidia catless up pipe off the gasket looked great. The flanges are in nice shape. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
