JJr Posted September 23, 2014 Share Posted September 23, 2014 OK this just started. At speeds below 30 mph I'm hearing a intermittent clunk or bump sound it does not do it continuously and sometimes when I hit bumps or imperfections in the road. It will do intermittently if I move the steering wheel back and forth rapidly too! I got under the car and inspected all suspension parts ( they all look great, RSB, F/R end-links were replaced 1 1/2 years ago) if the car is parked and I try to bounce the front end I get no sound whatsoever. Car has 91k, thx guys the sounds are driving me crazy, they aren't real loud either if the radio is up I don't hear them. Link to comment Share on other sites More sharing options...
nemo Posted September 23, 2014 Share Posted September 23, 2014 Might be the sway bar bushings. If you don't vote Trump, out, you're a bigot who hates america. Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 Sorry, just super lubed the rear last week. Are you referring to the front bushings? Link to comment Share on other sites More sharing options...
RedLGT Posted September 23, 2014 Share Posted September 23, 2014 Been trying to figure out something similar over here (http://legacygt.com/forums/showthread.php/clunk-after-clutch-replacement-137123.html). Just bought new end links and I'm hoping to install this evening. I'll post back later if I find anything interesting. Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 Good choice on the end-links, I installed the same Front/Rear they look good too. Link to comment Share on other sites More sharing options...
Code Posted September 23, 2014 Share Posted September 23, 2014 LCA, endlink, top-hat..... Do you own a torque wrench and a set of ramps? "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 Yes to all, check torque on everything? Makes sense. Link to comment Share on other sites More sharing options...
Code Posted September 23, 2014 Share Posted September 23, 2014 Yes to all, check torque on everything? Makes sense. Good luck. It'll probably take longer to find all of the torque-specs than it will to check everything. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 LOL, searching now thx! Link to comment Share on other sites More sharing options...
RedLGT Posted September 23, 2014 Share Posted September 23, 2014 Post what you find, I'll need it in like 3hrs! Lol Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 Thx Fred Beans Link to comment Share on other sites More sharing options...
discojon Posted September 23, 2014 Share Posted September 23, 2014 From FSM Link to comment Share on other sites More sharing options...
Max Capacity Posted September 23, 2014 Share Posted September 23, 2014 How are the tires wearing ? may be a bad ball joint. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 All DWS's were wearing evenly, just faster than they should have, received a nice credit and replaced them with MSP AS3's 1500 miles ago they are fine too. Will be checking torque on suspension parts tomorrow, will update too, all suggestions are appreciated. Link to comment Share on other sites More sharing options...
RedLGT Posted September 23, 2014 Share Posted September 23, 2014 Haven't had my car long enough to gauge tire wear... :/ Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 23, 2014 Moderators Share Posted September 23, 2014 Could the sway bar possibly need lateral locks to prevent side-to-side movement? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 Michael, Front is OEM with Moog End links, Rear is a Whiteline with lateral locks. Pulled on the sway bars really hard they seem fine. Link to comment Share on other sites More sharing options...
Akasa Posted September 23, 2014 Share Posted September 23, 2014 You've checked your Lower Control Arm bushings? They tend to crack and rip around 60k. Yes, 60k, they go fast. Mine are damaged at 86k miles and i'm getting a slight clunk over bumps. Any tear down the bushing, or missing chunks of the bushings will cause louder clunks over bumps. So inspect them closely, a good bushing will have ZERO tears or cracks. (Also, while you're down there, check your passenger side inner CV boot [closest to the trans] those like to fail around your milage.) That's odd that you're not hearing any clunk when you reef on the sway bar, my endlinks were loose, and clunked if I slalomed the car, tightening them fixed the issue. I don't really have much more useful information to add than that, sorry if I couldn't be helpful. Link to comment Share on other sites More sharing options...
Code Posted September 23, 2014 Share Posted September 23, 2014 Pulled on the sway bars really hard they seem fine. There is no way that you, pulling on a sway bar, can replicate the forces that are generated when the weight of the car shifts back and forth. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
Akasa Posted September 23, 2014 Share Posted September 23, 2014 Put the cars up on RAMPS (you need suspension load) and grab the sway bar ahead of the end link and reef it back and forth, that's how I found that my end-links were the issue. Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 There is no way that you, pulling on a sway bar, can replicate the forces that are generated when the weight of the car shifts back and forth. Will get under tomorrow and make sure everything is torqued to spec. The car will be on ramps. Code, are saying you think it has something to do with the FSB or links? Wonder why bumps and turning or cranking the wheel from side to side has no affect after 30 mph! Link to comment Share on other sites More sharing options...
JJr Posted September 23, 2014 Author Share Posted September 23, 2014 You've checked your Lower Control Arm bushings? They tend to crack and rip around 60k. Yes, 60k, they go fast. Mine are damaged at 86k miles and i'm getting a slight clunk over bumps. Any tear down the bushing, or missing chunks of the bushings will cause louder clunks over bumps. So inspect them closely, a good bushing will have ZERO tears or cracks. (Also, while you're down there, check your passenger side inner CV boot [closest to the trans] those like to fail around your milage.) That's odd that you're not hearing any clunk when you reef on the sway bar, my endlinks were loose, and clunked if I slalomed the car, tightening them fixed the issue. I don't really have much more useful information to add than that, sorry if I couldn't be helpful. Yes I checked the LCA's will do so again tomorrow. thx. CV boots looked good too. Link to comment Share on other sites More sharing options...
CrowNaza86 Posted September 24, 2014 Share Posted September 24, 2014 Can you feel the clunk through the dead pedal? Link to comment Share on other sites More sharing options...
discojon Posted September 24, 2014 Share Posted September 24, 2014 Could the sway bar possibly need lateral locks to prevent side-to-side movement? I think this may be my issue. I was only able to get one lateral lock on the front with my whiteline adjustable 23 mm. I feel like it is banging around. Link to comment Share on other sites More sharing options...
nm Posted September 24, 2014 Share Posted September 24, 2014 I had something like this and my knuckle had cracked where it attached to the LCA. You could feel it through the steering wheel. Link to comment Share on other sites More sharing options...
