SuperAkuma Posted June 16, 2014 Share Posted June 16, 2014 Sorry I hate to ask these type of questions but I did a search and I didn't see any results. I have a 2011 Legacy 2.5i. It came stock with 16" 205/60/16. I have a set of OBXT 17" rim that I want to use but I need some new tires. The stock tires that it has was 215/50/17. I would like go with the 225/50/17 because the diameter is closer to stock. The only thing that I am worried about is width. Stock is 8.07" while the new size is 8.86" wide. The car is stock height and I don't plan to lower it. Will I have any issues with rubbing when I make turns? Link to comment Share on other sites More sharing options...
Ellesedil Posted June 17, 2014 Share Posted June 17, 2014 According to cars101.com, the OEM tire size for a 17" '10-'12 Outback wheel is 225/60R17. But... the Outback is a SUV, not a sedan. For additional reference, the stock '10-'12 size for the Legacy GT is 225/45/18 +55 on a 18x7.5 wheel. It looks like you're going from a 16x6.5 +48 wheel to 17x7 +48. That will most definitely fit. As for the tire, 225/50R17 will certainly fit no problem, considering the GT has a 225 tire stock. http://willtheyfit.com/index.php?width=205&aspect=60&diameter=16&wheelwidth=6.5&offset=48&width2=225&aspect2=50&diameter2=17&wheelwidth2=7&offset2=48#content Link to comment Share on other sites More sharing options...
Kevjohn Posted June 17, 2014 Share Posted June 17, 2014 Stock tires on an OBXT is 225/55R17 not 225/50R17 Edit: I should read. I am answering a question that wasn't even asked. Link to comment Share on other sites More sharing options...
SuperAkuma Posted June 19, 2014 Author Share Posted June 19, 2014 My mistake it came off of the 2007 hatchback. Link to comment Share on other sites More sharing options...
SuperAkuma Posted June 23, 2014 Author Share Posted June 23, 2014 Update: Just got the tires install and it fits perfectly and no rubbing. It rides a lot better than stock and I can take the turns harder. Link to comment Share on other sites More sharing options...
