Max Capacity Posted May 31, 2013 Share Posted May 31, 2013 Just got a email saying the recall is offical for the corrosion on the four way joint. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Brunex Posted May 31, 2013 Share Posted May 31, 2013 What exactly about the brakes? Link to comment Share on other sites More sharing options...
Danteneon Posted May 31, 2013 Share Posted May 31, 2013 Yep, saw the update on Subarunet this morning. No parts will be replaced, just some undercoating sprayed on the junction. I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 31, 2013 Author Share Posted May 31, 2013 Your state is not part of the recall. Only northern states. I'll try and link you to the other threads about this. here's one. http://legacygt.com/forums/showthread.php/2005-2009-legacy-outback-brake-line-recall-206516.html Not much there, but the notice popped up in March this year. try this one. http://legacygt.com/forums/showthread.php/recall-2005-2009-legacy-and-outbacks-204977.html or here, http://legacygt.com/forums/showthread.php/05-09-legacy-outback-brake-line-corrosion-recall-204831.html Just made the appointment to have my wagon inspected June 11th at 4:15PM. I'm busy next week, don't have the time. She said they should have the parts on Monday to support any repairs needed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Danteneon Posted May 31, 2013 Share Posted May 31, 2013 They may have the parts. Subaru is shipping the undercoating the week of June 2nd, and should be at all dealers by that Friday. Also, if the car has ever been registered in the northern states, it qualifies for the recall. While I live in VA (which isn't on the list), the car was sold in Maryland (which is on the list) so my car gets the recall. I like to cook my pets and my family. Use commas. Don't be a psycho. Link to comment Share on other sites More sharing options...
iyalla Posted May 31, 2013 Share Posted May 31, 2013 Just got this email...oh joy. Link to comment Share on other sites More sharing options...
c-lo Posted May 31, 2013 Share Posted May 31, 2013 not a big deal. just scheduled mine for the 10th. takes about an hour she said. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Windy Road Posted May 31, 2013 Share Posted May 31, 2013 I also got the email. Rather not bring my car to the dealer, I don't trust them with my car. Plus in the 4 years I've owned my car its only been in two winters and they have been fairly mild winters at that. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
Max Capacity Posted May 31, 2013 Author Share Posted May 31, 2013 I also got the email. Rather not bring my car to the dealer, I don't trust them with my car. Plus in the 4 years I've owned my car its only been in two winters and they have been fairly mild winters at that. I'll be sitting with my car...waiting for them to do the inspection, I'll be there for the repair too if needed. I understand your concern about leaving the car and coming back later. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Windy Road Posted May 31, 2013 Share Posted May 31, 2013 I didn't check the other threads yet, but I want to know exactly where they are looking at "fixing" I'll do it my self. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
c-lo Posted May 31, 2013 Share Posted May 31, 2013 prediction about mine: with 226k on it, they'll come out and say: "ok...all done. btw....did you know that this needs to be replaced....." 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos Link to comment Share on other sites More sharing options...
Max Capacity Posted May 31, 2013 Author Share Posted May 31, 2013 prediction about mine: with 226k on it, they'll come out and say: "ok...all done. btw....did you know that this needs to be replaced....." Your talking about the car... right ? LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
theflystyle Posted June 1, 2013 Share Posted June 1, 2013 i personally find the fix a little off putting. they simply place a rust prohibitor on the problem areas and replace if needed Link to comment Share on other sites More sharing options...
jp233 Posted June 1, 2013 Share Posted June 1, 2013 Yeah, it is a simple inspection to do yourself, that's for sure. Just requires two people to actually check for any fluid leakage when you stomp on the brake pedal. If it's rusted enough, I don't see how spraying it with rust inhibitor really fixes it, it just prolongs it maybe a bit. Either way, I'll be having the dealer look at it when I get the car back on the road... it was an MD car, so its eligible. If it were a GA car, it would have been rust-proofed by some GA red clay! haha Link to comment Share on other sites More sharing options...
BX77 Posted June 1, 2013 Share Posted June 1, 2013 Where is this 4 way Front or Back or both. I replaced my Brake lines with SS, does that effect what they are looking for? Link to comment Share on other sites More sharing options...
BX77 Posted June 1, 2013 Share Posted June 1, 2013 Just did a search and saw the picture in the release, Wow that search feature is pretty cool, we always had it! Link to comment Share on other sites More sharing options...
lee07 Posted June 1, 2013 Share Posted June 1, 2013 What if it already was rustproofed? Previous owner rustproofed the undercarriage Link to comment Share on other sites More sharing options...
iNVAR Posted June 2, 2013 Share Posted June 2, 2013 Here's the recall, photos inside too: http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM435906/RCDNN-13V110-2693.pdf Link to comment Share on other sites More sharing options...
aziankingz Posted June 2, 2013 Share Posted June 2, 2013 I guess i will do this. Can I do this even if i didn't get a letter? Link to comment Share on other sites More sharing options...
K2e2vin Posted June 2, 2013 Share Posted June 2, 2013 Your state is not part of the recall. Only northern states. Luckily I double checked, but this recall applies if the car was ever registered in those northern States too(which is my case,car was originally from NJ). If there's a recall, yes, you can have it checked out. I never received a letter(got my car used) but it shows up for my car on the Subaru website. Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted June 2, 2013 Share Posted June 2, 2013 I like the repair time, 18min. if lines are ok & a ply rust proofing. 7hrs. if line need to be replaced. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
06legsleeper Posted June 3, 2013 Share Posted June 3, 2013 i just got a email last week and got a letter today from subaru of america... i dont have time to get it looked at least not till end of the month so guess ill get a appointment then ... Link to comment Share on other sites More sharing options...
Max Capacity Posted June 3, 2013 Author Share Posted June 3, 2013 I guess i will do this. Can I do this even if i didn't get a letter? Luckily I double checked, but this recall applies if the car was ever registered in those northern States too(which is my case,car was originally from NJ). If there's a recall, yes, you can have it checked out. I never received a letter(got my car used) but it shows up for my car on the Subaru website. I would think that you could go to the dealer, have them check your VIN and find out the car was sold in the snow belt states. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BX77 Posted June 3, 2013 Share Posted June 3, 2013 Got my letter Today, Have to make an appointment Link to comment Share on other sites More sharing options...
iNVAR Posted June 3, 2013 Share Posted June 3, 2013 Got my letter today too, time to make an appointment. Link to comment Share on other sites More sharing options...
