cheap simple cubby mount
RustyShackleford
I built this simple mount for attaching my Sirius radio to my cubby.
First, I found a scrap piece of aluminum lying around, about 1/16"
thick. I shaped the end to fit snugly into the cubby, up against the
side wall closer to the driver. Then I bent it. Then I drilled 4 holes
in the AMPS-style pattern used by Sirius radios. Then I painmted it
black, first using a special primer (you can't just paint aluminum directly).
The fit was snug enough to hold my Stratus 4 (very light). But I used
some velcro to hold it against the side of the cubby. Or you could glue it.
The mount is removable, still allows access to the cubby (for holding
knick-knacks), and is free (if you have basic tools and an appropriate
metal scrap lying around).
I still need to use some sort of cable tie to neaten up the wires ...
Didn't want to be rude... I'm not the kind of guys who think cute, so it's perfect for me.
I would prefer to have a rally car dash with all options than a cute OEM with less options. but well... resell value :(
