Heffernan Posted September 10, 2013 Share Posted September 10, 2013 So over the past few weeks I have been slowly gathering parts to complete a full LGT brake swap on my Outback. Outside of the obvious, things like calipers, rotors and pads, is there anything else I need to make sure I have before diving into this project? I don't want to get half way through and realize I am missing something. Seems like a fairly straight forward process, but I just want to double check before I start. Thanks! Link to comment Share on other sites More sharing options...
whitetiger Posted September 10, 2013 Share Posted September 10, 2013 should be a piece of cake. remove rotors and calipers, then reinstall LGT ones. just make sure you do a good job getting all the air out of the brake lines. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted September 10, 2013 Moderators Share Posted September 10, 2013 The hardest part is probably anything to do with brake line fittings. Other than that it should be very straight forward. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Heffernan Posted September 10, 2013 Author Share Posted September 10, 2013 I'm assuming that I can use the OB lines....? I've heard that LGT lines are too short or something. I was looking into SS brake lines for LGT and was told they wouldn't work because of shorter length... If someone has heard different please let me know. Link to comment Share on other sites More sharing options...
N.sane Posted September 10, 2013 Share Posted September 10, 2013 I used the LGT brake lines; I'm not sure if the Outback/2.5i lines work. Also make sure there's clearance between the new rotors and dust shields. I had to bend of the dust shields back a bit to keep it from grinding against the rotor. Link to comment Share on other sites More sharing options...
whitetiger Posted September 10, 2013 Share Posted September 10, 2013 use the OB lines. just get new banjo bolts and copper washers. and of course bleed the system well. Link to comment Share on other sites More sharing options...
Heffernan Posted September 10, 2013 Author Share Posted September 10, 2013 use the OB lines. just get new banjo bolts and copper washers. and of course bleed the system well. Any chance you have PNs for those items? Link to comment Share on other sites More sharing options...
Lucid Posted September 10, 2013 Share Posted September 10, 2013 I got LGT ss brake lines when I did the LGT brake swap. Fit perfect. Link to comment Share on other sites More sharing options...
whitetiger Posted September 11, 2013 Share Posted September 11, 2013 Any chance you have PNs for those items? search here - http://opposedforces.com/parts/legacy/us_b13/ Link to comment Share on other sites More sharing options...
Heffernan Posted September 11, 2013 Author Share Posted September 11, 2013 I got LGT ss brake lines when I did the LGT brake swap. Fit perfect. Hmmm... what kind did you get? I was looking at Goodridge SS lines. Link to comment Share on other sites More sharing options...
Lucid Posted September 11, 2013 Share Posted September 11, 2013 Hmmm... what kind did you get? I was looking at Goodridge SS lines. Yep, I used the Goodridge kit. Link to comment Share on other sites More sharing options...
Heffernan Posted September 12, 2013 Author Share Posted September 12, 2013 Yep, I used the Goodridge kit. Interesting. I guess I'll order them and if they don't fit I'll just return 'em. Link to comment Share on other sites More sharing options...
