SeattleLegacy Posted July 27, 2012 Share Posted July 27, 2012 So, i'm in the process of replacing my head gaskets (there is coolant leaking out of the driver-side externally and exhaust in the coolant). Some details of my car: 119,500 miles; no engine mods; full synthetic since 15k miles. What size is the crank bolt? Its larger than 21mm (the largest socket I have) and I don't have a micrometer to measure. The throttle body on the manifold side is completely carbon/oiled covered. This doesn't seem normal. I expected some buildup, but this looks like another level. Opinions? What could cause this if it isn't normal? http://farm9.staticflickr.com/8166/7654787544_3347bf5449_b.jpg http://farm9.staticflickr.com/8002/7654788010_34ff2d6839_b.jpg http://farm8.staticflickr.com/7139/7654787136_365222342b_b.jpg Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 27, 2012 Share Posted July 27, 2012 Crank bolt is 22mm. The build up is normal for a high mileage non-turbo H4. Link to comment Share on other sites More sharing options...
SeattleLegacy Posted July 27, 2012 Author Share Posted July 27, 2012 Thanks. Picked up the socket and exra intake/throttle body cleaner. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted July 27, 2012 Share Posted July 27, 2012 Thanks. Picked up the socket and exra intake/throttle body cleaner. Thats the stuff use the whole can and plenty of shop towels Link to comment Share on other sites More sharing options...
SeattleLegacy Posted July 28, 2012 Author Share Posted July 28, 2012 Any ideas on getting the bolt that holds the crank pulley loose? I've given it two shots of penetrating oil and used a cheater bar but no luck. Maybe an overnight soak will do the trick. I've gotten as far as I can go and this has stopped all progress. I've cleaned the throttle body and i've done some of the intake manifold. Looks like it will come out almost as good as new. Link to comment Share on other sites More sharing options...
burnout8488 Posted July 28, 2012 Share Posted July 28, 2012 Breaker bar with 2...3...4+ feet of extension will get it off. Look around your garage and keep looking for bigger and bigger pipes to put on the handle. Link to comment Share on other sites More sharing options...
