bryanf Posted July 22, 2009 Share Posted July 22, 2009 I recently had the 105 and 120k service done (car has 115k so I just did them both) on my 05 LGT MT and I swear the car is SIGNIFICANTLY slower now. I also had a camshaft position sensor replaced at the same time (car was stalling and had CEL lights). It doesn't even feel like it is a turbo anymore. The shop says that the car is in 'default mode' because they reset ECU, and that the car will get better over the next 100 miles or so. Is that true? It sounds flaky to me, but this is a pretty reputable shop... Could they have screwed something else up during the service (cam timing wrong, wrong plugs)? The car runs great otherwise and gets better mileage...it is just SLOW. Ideas? TIA Link to comment Share on other sites More sharing options...
Platinum_Racing Posted July 22, 2009 Share Posted July 22, 2009 Cam timing possibly. How's the idle? Link to comment Share on other sites More sharing options...
bryanf Posted July 22, 2009 Author Share Posted July 22, 2009 The car runs great in all other respects...starts easily, idles smooth, gets great mileage...it feels like I only get about 1/2 the power... Link to comment Share on other sites More sharing options...
Max Capacity Posted July 22, 2009 Share Posted July 22, 2009 May be they knocked a vacuum line off of the turbo system. Isn't there some little sensor forward of the intake manifold on the top right hand side of the engine that has a vacuum line going back to the turbo? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
John M Posted July 22, 2009 Share Posted July 22, 2009 For timing belt on a Subaru, I'd stick with a dealership or an import shop that specializes in Subarus. It's just too much work to trust just any guy with a set of tools and an Alldata subscription to do it properly. Link to comment Share on other sites More sharing options...
nka Posted July 22, 2009 Share Posted July 22, 2009 and that the car will get better over the next 100 miles or so. True... but not for the 1/2 performance... ! Link to comment Share on other sites More sharing options...
ehsnils Posted July 22, 2009 Share Posted July 22, 2009 Since the car runs great otherwise I would check the vacuum lines and also the wastegate on the turbo. And I would also check the turbo itself - just in case someone lost a nut into the exhaust or intake and jammed it. That would really suck. Link to comment Share on other sites More sharing options...
bryanf Posted July 22, 2009 Author Share Posted July 22, 2009 This is ridiculous. This morning I couldn't keep up with a Prius going over the coastal mountains...and I don't think he was even racing me. Can anyone tell me more about the vacuum lines to the turbo? Do they need to be disconnected for a timing belt change or major tune. By the way, the shop was Kunos in Redwood City...they came highly recommended and specialize in Subaru, Toyota, and Honda/Acura Link to comment Share on other sites More sharing options...
Max Capacity Posted July 22, 2009 Share Posted July 22, 2009 Default mod will not cut your power in half. When you plug the negative battery cable for a minute or so it resets the ECU. The care should run fine. I did my own timing belt and the car was the same afterwards. They messed something up. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RJS5689 Posted July 23, 2009 Share Posted July 23, 2009 For timing belt on a Subaru, I'd stick with a dealership or an import shop that specializes in Subarus. It's just too much work to trust just any guy with a set of tools and an Alldata subscription to do it properly. What's so special about the timing belt in a Subaru... Link to comment Share on other sites More sharing options...
Platinum_Racing Posted July 23, 2009 Share Posted July 23, 2009 ^^^^ +1 Not much, if you've done one timing belt, you can do em' all. I'd bring it somewhere else and have them check the timing anyway though. Link to comment Share on other sites More sharing options...
Guest Posted July 23, 2009 Share Posted July 23, 2009 I vote on screwed timing belt job. They are feeding you BS. Look up vacation pix with timing belt info, have them remove timing belt covers and count the teeth on the belt as the vacation pix say. Link to comment Share on other sites More sharing options...
OBieXT Posted July 23, 2009 Share Posted July 23, 2009 What's so special about the timing belt in a Subaru... 4 camshafts ==> more chances to screw up Apparently they took advantage of this opportunity... Link to comment Share on other sites More sharing options...
John M Posted July 24, 2009 Share Posted July 24, 2009 Exactly -- the more there is to line up, the greater the chance someone wasn't taking their time. It's not rocket science but it isn't a Civic either. Link to comment Share on other sites More sharing options...
bryanf Posted July 30, 2009 Author Share Posted July 30, 2009 Okay...here is the latest. The mechanic said that the car has no faults stored in the ECU and they checked the cam timing and it's okay. They can see that the turbo starts to spool up, but for some reason doesn't reach full boost. They suspect two possibilities: 1) the car is dumping the boost because it is detecting a knock due to bad gas, or 2) the turbo is bad and not generating full boost. I doubt that it is the gas because I have filled the car a couple of times, and I have trouble thinking of a failure mode where the turbo just 'kind of' works. They say the next step is to dig into the turbo to see if it is functioning correctly--4 hrs of shop time (ouch). We agreed that I should run a few tanks of gas through the car just to make sure it isn't the gas. Are they overlooking something (bad knock sensor?) that would cause the car to dump boost?? Any help is greatly appreciated!! By the way--the shop did this diagnostic work for free (kudos to Kunos of RWC) Link to comment Share on other sites More sharing options...
05pearl Posted July 30, 2009 Share Posted July 30, 2009 Any number of issues could cause your turbo to be limited to wastegate pressure (which is what it sounds like). Resetting th ECU should put you back to full boost if it's bad gas. If you reset and no full boost, it's most likely not bad gas. If it is full boost, then it may be the gas, so drive carefully so you don't over knock at first, and then run until you can put better gas in. Bad turbo? - that's a stretch considering it happens to "fail" right after they work on your timing belt. I would have them check for vacuum leaks... Other's may chime in here as several things can contribute to turbo only reaching WG duty. Not enough info to tell from this end. Link to comment Share on other sites More sharing options...
TPLGT Posted July 30, 2009 Share Posted July 30, 2009 Subscribed. Rehab is for quitters. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 30, 2009 Share Posted July 30, 2009 May be they knocked a vacuum line off of the turbo system. Isn't there some little sensor forward of the intake manifold on the top right hand side of the engine that has a vacuum line going back to the turbo? Did they check for a vacuum leak ? That's the easy fix. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
robinlsb Posted July 30, 2009 Share Posted July 30, 2009 1, Get a compression test pronto:mad: 2. If compression test is ok, the timing belt is a half tooth off. Common for 4 camers. 3> my bet is the belt is a half tooth off. That can impact the timing by as much as 20 degrees, but you won't always throw a code. "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
