JayInVA Posted December 11, 2014 Share Posted December 11, 2014 The title pretty much says it all. My driver's side low beam headlight is significantly dimmer (but lit) than the passenger side. I've replaced the bulb multiple times so I don't believe that is it. I just replace the "front" section of the wiring harness (a small section that connects the driver's side low and hi beams to the rest of the harness) but it's still dim. Again, all of the other lights work perfectly (both high beams, passenger low beam, yellow turn indicators, etc). Any ideas? It's driving me insane (and I just got a ticket for it ). Link to comment Share on other sites More sharing options...
MrTris Posted December 11, 2014 Share Posted December 11, 2014 Here, [ame=http://www.amazon.com/Kensun-Conversion-Colors-Digital-Ballasts/dp/B004ZF3DYG/ref=sr_1_2?ie=UTF8&qid=1418312804&sr=8-2&keywords=Kensun+HID&pebp=1418312808554]NO MORE DIM LIGHTS[/ame]! I personally installed and use this kit -- it's legit. Link to comment Share on other sites More sharing options...
mkee87 Posted December 11, 2014 Share Posted December 11, 2014 I second that that kit is awesome, thats what I've got. And the case made a nice box for my g29sf. Link to comment Share on other sites More sharing options...
MrTris Posted December 11, 2014 Share Posted December 11, 2014 I second that that kit is awesome, thats what I've got. And the case made a nice box for my g29sf. Is that like, a pot vaporizer or something? Link to comment Share on other sites More sharing options...
mkee87 Posted December 11, 2014 Share Posted December 11, 2014 I have vaporized a few pots with it lol. It's a glock compact 10mm. Link to comment Share on other sites More sharing options...
MrTris Posted December 11, 2014 Share Posted December 11, 2014 I have vaporized a few pots with it lol. It's a glock compact 10mm. I searched. Link to comment Share on other sites More sharing options...
JayInVA Posted December 11, 2014 Author Share Posted December 11, 2014 Thanks MrTris. I'll look into that. However, after doing a little bit of testing, I don't the issue is the actual light output. To the naked eye, it looks like the lights are both burning at the same brightness (outside of the light assembly). However, for some reason the light doesn't escape the housing at the full brightness. I'm sure it's not the outer plastic lens (they've both been cleaned/restored and the high beams pass through no problem). It's like the light is trapped in the round projector-like lens. Guess I'll try cleaning that (any way to do that without taking out the entire assembly? Link to comment Share on other sites More sharing options...
MrTris Posted December 11, 2014 Share Posted December 11, 2014 Guess I'll try cleaning that (any way to do that without taking out the entire assembly? Nope. Might as well go ahead and clear and/or modify your headlights while you're there, which, in that case, just go HID when you're done, too - See the Modified Headlight Picture Thread and the How To Clear Your Headlights thread - Link to comment Share on other sites More sharing options...
JayInVA Posted December 11, 2014 Author Share Posted December 11, 2014 This is driving me nuts. It's like the light is being trapped inside of the headlight assembly. I can't see any direct or obvious cause. Link to comment Share on other sites More sharing options...
12sechatch Posted December 12, 2014 Share Posted December 12, 2014 and the bulb is properly 'seated' in the housing? Link to comment Share on other sites More sharing options...
JayInVA Posted December 12, 2014 Author Share Posted December 12, 2014 and the bulb is properly 'seated' in the housing? Yes, as far as I can tell. The tab on the side of the bulb is aligned with the cutout in the housing, if that's what you mean. Anyway, I ordered a "like new" headlight from Amazon for $80 bucks. If you're familiar with Amazon you'll know that "Like new" usually means new/unused with slightly damaged packaging so I consider that a good deal. Link to comment Share on other sites More sharing options...
MrTris Posted December 12, 2014 Share Posted December 12, 2014 Yes, as far as I can tell. The tab on the side of the bulb is aligned with the cutout in the housing, if that's what you mean. Anyway, I ordered a "like new" headlight from Amazon for $80 bucks. If you're familiar with Amazon you'll know that "Like new" usually means new/unused with slightly damaged packaging so I consider that a good deal. Jesus H. Christ! The HID kit was less than that! WHY? Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 12, 2014 Share Posted December 12, 2014 I think he thinks it's a housing issue, not a lamp issue- hence the ordering of a new headlamp assembly.... Link to comment Share on other sites More sharing options...
MrTris Posted December 12, 2014 Share Posted December 12, 2014 I think he thinks it's a housing issue, not a lamp issue- hence the ordering of a new headlamp assembly.... $80 for the housing seems like a screaming deal. I thought he meant light, as in, just one. Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 12, 2014 Share Posted December 12, 2014 Hopefully it won't be a crappy fitting depo, but probably is.... Link to comment Share on other sites More sharing options...
AF_3C2 Posted December 12, 2014 Share Posted December 12, 2014 Did a quick search on Amazon, the cheapest I found was $120- guess he will post how he got one for $80.... And the $120 was for DEPO.... Link to comment Share on other sites More sharing options...
JayInVA Posted December 14, 2014 Author Share Posted December 14, 2014 $80 for the housing seems like a screaming deal. I thought he meant light, as in, just one. Hopefully it won't be a crappy fitting depo, but probably is.... Did a quick search on Amazon, the cheapest I found was $120- guess he will post how he got one for $80.... And the $120 was for DEPO.... $80 was from Amazon Warehouse so it's not a deal that can necessarily be replicated (Warehouse stock is revolving). Customer service rep said the outer packaging had minor damage so they can't sell as new which is why it was listed under Amazon Warehouse and sold as "Used - Like New." Yes it was DEPO but not too concerned about it. With Amazon returns are easy enough if I'm not happy with it. Plus, I've seen DEPO used on other member's cars and I didn't see any fitment issues. My main concern is light pattern/field of vision (which is one reason I didn't go with their "HID" version). Someone else said they had a pretty narrow light pattern, so I'll test it to see how it compares to my OE. Link to comment Share on other sites More sharing options...
boxman Posted December 14, 2014 Share Posted December 14, 2014 Double check that the bulb is seated properly. I had one like this and it was totally my fault for not having the bulb seated properly. Link to comment Share on other sites More sharing options...
JayInVA Posted December 15, 2014 Author Share Posted December 15, 2014 Just got the new Depo assembly. Looks good! Did a quick test (just plugged in the low beams) and it appears to be working perfectly. I guess that means the problem was, in fact, something to do with my headlight assembly. I guess when I install the Depo unit I'll mess around with the old one to see what was going on. Also, Amazon is pretty amazing. Ordered it Friday and got it Monday for $80 shipped. Link to comment Share on other sites More sharing options...
