05-09 LGT Intake SALE
Subimods
Just right to the point. Find it cheaper? Let me try and beat it! Looking for additional parts or don't see something here, PM ME!
http://www.jscspeed.com/images/catalog/category4801_thumb.jpg
AEM Cold Air Intake (05-09 LGT)
  • Available in Blue, Silver, & Polished
  • Retail: $380
  • Sale Price: $235
  • AEM's 05-09 Subaru Legacy GT Cold Air Intake relocates the air filter outside of the engine compartment to deliver the coolest air inlet temperatures possible. A intake heat shield gives you extra protection against engine heat and cooler air carries more oxygen which translates into a more intense explosion in the combustion chamber. These intake systems feature dry flow air filters for the best performance and almost zero maintenance. Every AEM Cold Air induction system is constructed to the highest standards and are guaranteed for the life of your vehicle.
http://www.jscspeed.com/images/catalog/category4815_thumb.jpg
K&N Typhoon Short Ram Air Intake (05-09 LGT)
  • Available in Black
  • Retail: $470
  • Sale Price: $235
  • K&N is proud to introduce their Typhoon short ram intake system for the 05-09 Legacy GT. This intake features a mandrel bent aluminum intake pipe coated black and a K&N cone filter, a trusted name in performance air filtration for decades. The K&N intake system also utilizes a heat shield designed to keep ambient engine heat away from the filter, allowing for a more dense intake charge than conventional short ram intakes. This unit deletes the restrictive factory air box and is designed to increase airflow pre-turbocharger, a concept that is key to making more power in any performance vehicle. K&N has produced some very impressive numbers with their Typhoon line of intakes, gaining up to 14whp on an otherwise stock Legacy GT. All K&N products are backed by a million mile limited warranty so rest assured you are getting the highest quality product possible.
http://www.jscspeed.com/images/catalog/category5226_thumb.jpg
COBB SF Short Ram Air Intake (05-09 LGT)
  • Available in Blue & Black
  • Retail: $195
  • Sale Price: $195
  • Cobb's SF Legacy GT Intake system utilizes several unique features in an effort to maintain optimal flow for performance while minimizing turbulence that can cause engine management problems. Cobb's straightener grid is specifically designed to smooth the incoming air flow as it passes the Mass Air Flow (MAF) sensor for precise readings. This eliminates the "dead spots" caused by intake turbulence. In order to provide a Legacy GT intake system that looks as good as it functions, Cobb utilized a one-piece plastic high-temperature composite plastic body. Not only does this save weight, it also prevents heat soak, keeping incoming air cooler. You will not find a more researched & developed short ram intake for your Legacy GT than the Cobb SF.
http://www.jscspeed.com/images/catalog/category5228_thumb.jpg
COBB SF Air Box (05-09 LGT)
  • Retail: $135
  • Sale Price: $135
  • The Cobb Tuning SF Air Box was designed to capture the cool air supplied to the SF intake through the factory intake snorkle. The aluminum heat shield consists of a one piece surround, directional lid, and stainless fasteners that help reduce a loss of power that could be robbed from your motor by a heated intake charge.
http://www.jscspeed.com/images/catalog/category22023_thumb.jpg
COBB MAF Block Off Plate (05-09 LGT)
  • Retail: $45
  • Sale Price: $45
  • The Cobb Tuning MAF Block-Off Plate Kit is the perfect complement to Speed Density tuning. Speed Density tuned vehicles use a MAP sensor instead of your Subaru's MAF sensor. Removing the MAF sensors eliminates points of restriction and turbulence in the intake tract, but it needs to be done correctly. The Cobb Tuning MAF Block-Off Plates are the easiest way to safely delete the MAF sensors for optimal performance with the added bonus of great looks. The billet 6061 T6 aluminum and CNC-machined plates seal off the openings left when the MAF sensors are removed. The kits are finished off with stainless steel button-head screws and black nylon washers that give the plates a professional appearance when installed.
http://www.jscspeed.com/images/catalog/category4793_thumb.jpg
K&N Drop-In Air Filter (05-09 LGT) & (10-11 LGT)
  • Retail: $70
  • Sale Price: $35
  • K&N's Legacy GT replacement air filters are designed to increase horsepower and acceleration while providing excellent filtration. K&N filters are custom designed to fit into your existing factory air box for simple, fast installation. K&N stock replacement air filters for street vehicles are covered by a Million-Mile Limited Warranty. K&N Filters use oil to provide filtration, and can be washed and recharged using the K&N cleaning kit (sold separately).
http://www.jscspeed.com/images/catalog/category4799_thumb.jpg
Perrin Afta-MAF Silicone Hose (05-09 LGT)
  • Available in Black & Red
  • Retail: $85
  • Sale Price: $70
  • Perrin's Afta-MAF silicone air box hose for the 05-09 Legacy GT features 5-ply silicone construction and vibrant color. Replacing the stock corrugated rubber hose between the turbo inlet and factory air box will allow for improved airflow due to higher internal volume and smoother airflow due to the smooth interior. This product is the perfect compliment to a Perrin turbo inlet hose. The Perrin MAF hose is designed for use with the stock air box, but will work with any intake designed to use the stock rubber hose. Must have stock air box.
http://www.jscspeed.com/images/catalog/category22815_thumb.jpg
Venair MAF Hose (05-09 LGT)
  • Available in Black, Red, Yellow, & Blue
  • Retail: $80
  • Sale Price: $65
  • Treat your Legacy GT to a Venair performance MAF hose kit that will add both show and go! Venair is the global leader in the performance automotive silicone products and accessories with over 26 years of high quality manufacturing in the medical, industrial, locomotive and automotive industry. Production of all Venair performance automotive silicone kits is done exclusively in house at one of their three locations using state of the art ISO 9001, 14001 and TUV certified facilities. Venair performance silicone hose kits are application specific and guaranteed for a perfect fit and finish. The Venair MAF hose kit for the Legacy GT fits after the MAF sensor housing, connects directly to the turbo inlet and is available in red, blue, black or yellow.
**Air Filter Cleaning Kits Are Also Available, CONTACT US!
AIM: SUBIMODS
SKYPE: SUBIMODS
  • 4 weeks later...
  • Replies 87
  • Created
  • Last Reply
  • 3 months later...
  • 1 month later...
  • 2 weeks later...
  • 2 weeks later...
  • 2 weeks later...
